frustrated'hoeowner
- Joined
- Jun 21, 2011
- Posts
- 8
- Reaction score
- 0
I am new here and this is a first posting anywhere so bear with me.
I have a 1997 tahoe 350 5.7L 4 door 2wd. Has just over 141K on it. A head gasket blew and cracked a head so i bought new heads online as well as a full gasket set, cap, rotor, wires, spark plugs.
After banging head repeatedly on not getting the dist in right, and getting a million dtc's and not running right if at all, someone finally pointed me in the right direction. I lined the marks on the gear to the shaft while being set at tdc on compression stroke. Once dist was set right it hesitated starting (mainly from a dead battery i suppose) but once it started it ran great and no dtc's! drove about 5 miles and other than a weak brake pedal i was thrilled. I had also burned a hole in #1 wire so once back from test run i put new set on. started it up and immediately got a code; i beleive p1345. along with a couple of others. At one point it wouldnt start w/o foot on throttle. late last night it decided to not even turn over, just get a click even with jumper cables.
since rebuild of top end i have gotten dtc's for just about every electrical component there is and most went away.
Prior to blown head gasket i had not a single problem with it. Now i am at a loss as to what to do or where to start.
Please help, this has taken entirely too many hours and headaches! I just want to be done! BTW i have limited income so maybe its time to cut loses?
Sorry for the long post just figured easier to post all info that i know. Thanks guys.
the Bosch plugs are killing the efficiency of you burn. delco plug 41-993.
