brake upgrade!( 07 fronts)
slocaddy
sarasota fl
im finaily tired of listing to jinglebells everytime i go over bumps, and with 165,000 and who knows if brakes were ever done- i orderd parts! Got some drilled and slotted rotors 07 fronts stock rears, they are supposed to match. ill probably use the pads they come with for now they supposedly some kind ''performance ceramic''. just have to get calipers and brakets now. will post pics when i do the job.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Nice, but i hear it better to go just slotted though. What you end up getting?
slocaddy
slocaddy
sarasota fl
drilled and slotted. is that because drill holes are prone to craking? had the option of either or bolth, didnt even think of that.
Huck
Whut Thee Huck?!
San Diego
Unless you're racing drilled rotors are perfectly fine. You're not putting the type of stress on them that is going to cause cracking. Slotted rotors may force you to replace the pads more often, but it's not a huge difference.
slocaddy
slocaddy
sarasota fl
well these brakes are incredible! only done a short amount driving. deff the best bang for your buck, if your going to spend money on your brakes anyway might as well spend a little more for this stuff! I have never driven any aftermarket brake systems so i cant give a compairison, but considering what those systems go for( deff out of of reach for me! ) i dont think this can be beat.
my parts are:
07 loaded calipers(because you have to get the caliper braket also)
07 front rotors/ 03 rears(got mine off ebay and were the same thikness as stock
ceramic pads nothing special
Ive got about $500 into this doing it myself, THIS IS DIRECT BOLT ON! nothing special needed! only thing im not sure of is if it will clear the 16'' spare. go to my albums for some pics.
blueflamed03
Oklahoma
wow...good deal, so all you did was order 07 rotors, front and rear, and front and rear 07-up calipers?
slocaddy
slocaddy
sarasota fl
rears are stock 03's (calipers and rotors). Ive read that the 07 and up rears are actually smaller. Only the fronts are 07 and up.(rotors and calipers ) just make sure you get the caliper braket also. only way i could get them where i am was to buy a ''loaded caliper''
jdpber
GOLD MEMBER
The America
where did you get your calipers? are they dual or single piston calipers? and what size are they over the stock 03 model ones
slocaddy
slocaddy
sarasota fl
napa for calipers- the rotor is an inch bigger. the calipers are 2 piston and are also bigger in size.
theres a pic of the old front rotor and new one side by side in my album.
TheYuk
Atlanta
You can get the calipers without getting them loaded with pads but still come with bracket. The CARQUEST part numbers are, Left 18B-4919, Right 18B-4918, and 90% of stores keep them in stock and if not they are readly avalable.
jdpber
GOLD MEMBER
The America
alright so i used the onlune 40% off advanced auto coupon code and this is how it brakes down.. lol
brackets 2x 27.99 - $51.61
left and right caliper - 2x $93.99
pads Ceramic Brake Pads - 42.26
total - $281 shipped
plus a set of drilled rotors on ebay - 130
grand total $411 - (100 core when returned) = $311
Not a bad price in my opinion to upgrade full front brake system.. order is being placed. also a set of rear drilled rotors.. for $130 making the total 4 wheel upgrade $440. and if i find that the calipers come with the brackets can shave another 50 off..
slocaddy
slocaddy
sarasota fl
Napa was my only option localy advance told me they couldn't even get brakets. When do plan on installing?
gdddup
NJ
look for a1 cardone calipers they can come loaded with bracket pads caliper and hardware. or just bracket caliper and hardware or just bare calipers... im def gonna be doing this upgrade soon
slocaddy
slocaddy
sarasota fl
Same one I read also, very good thread- Much more in deph. I think the guy who started it is a member on this forum
jdpber
GOLD MEMBER
The America
Well My prices have dropped.. i can now get the NEW non re manned Calipers with bracket for $53 each plus a $50 core from Advanced AUTO... and order my rotors and pads.. so new grand total after return cores is going to be about 280-300 i didnt factor tax.. so we can round up to $300 for 13" brake upgrade in the front. add another $150 for the rear slotted and pads.. so i have $450 in a full upgrade.. parts are ordered on the next pay check.. adn ill have to find te time to install...
slocaddy
slocaddy
sarasota fl
my local advance is poopy. like the tow mirrors! your truck being lifted can pull it off. I bought a set for my wifes duramax dually and considerd putting them on the caddy for a little photo shoot:Boo:
riso79
So Cal
my parts are:
I am just waiting for my brakes to wear out so I can do the same swap. You will have to get a larger spare, the 16 will not clear the rotors. Too bad your no in So Cal, I would trade you a 17 spare, I have 2 left that I am trying to get rid of. Anyone else local doing this swap PM me.
SBK RACER
Question....
Are the 2007 Tahoe / Yukon the same Calipers and rotors that the 2006 Suburban 2500 / Yukon XL 2500 use?
Thanks!
Jumpshot12
