Looking for front end ideas after a body lift
custom99
Pittsburgh, Pa
I put a 3 inch body lift on. The valance now no longer fits without cutting it up. They give you ugly rubber pieces to fill in the areas after you cut sections out to make the valance fit again. Does anyone have any cools ideas of what I can do to make the front end look good? Bolt on, fabricate, give me some ideas. Removing the body lift is not an option.
<a href="http://s1108.photobucket.com/albums/h403/custom99/?action=view&amp;current=yukon002.jpg" target="_blank"><img src="http://i1108.photobucket.com/albums/h403/custom99/yukon002.jpg" border="0" alt="2003 Yukon XL after"></a>
MOBmentality
Has a $25,000 Punch
I have no clue.. but i thought id help with your image issue
KAKALAK
look in the truckin mag and at the ads in there. I bet they got something
2005yukonxl
remove the body lift :) haha oh wait. u said thats not an option. but really, IMO to make it look good/right thats the only way. do a proper suspension lift because its not only the front end...the rest of it kinda looks odd now too.....
but back to your topic, perhaps if you got a replacement bumper like a ranch hand or something (even though i think they are hideous) that would "fix" whatever is wrong? i dunno...or if they can even be used with a cheap lift...not sure.
MOBmentality
Has a $25,000 Punch
Wow.. not alot of positivity going on in here.. body lifts are fine.. (imo only WITH a suspension lift also) you can probably just do some trimming and make it work bro.. sorry i cant be more help
brucebruce45
Cut the frame down where it's hittin the valance. Had to do it on mine
MOBmentality
Has a $25,000 Punch
Brandon FTW trimming the horns on the frame sounds like an easy solution
Rcarew907
