01 tahoe door panel removal
Nortex
Can someone tell me how to take my door panels off without breaking them?
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Ill +1 you on that
I'm new Ishmael and attepmted it once but got scared I was removing it wrong so I shoved it back in...I need to get to my passenger side tweeter thing feel out of place..
Sent from my SCH-I500 using Tapatalk
Doomsta510
510 Albany/Richmond Ca.
There's a few screws you need to remove in order for the panel to come off. There's a hole under the arm rest with a screw inside, theres also about 2 or 3 screws running the bottom/front of the door. You will also have to pop off the trim piece around the door handle(pops right off)
2005yukonxl
once all the screws are out remember GM uses a little different tab than alot of makers...alot of makers use ones that pull straight out. not gm. they have tabs that u have to lift up on the door panel and out to get them out of the holes in the doors.
whitehoe01
the door will have 3-4 hex's in it that you have to take out. and simply pull up on the door...
im gonna replace my morel tweeters today with my new eton's. (sound 3x better) i can take pics for you if you'd like... dont really have time for a right up but i can set you in the right direction
Yukon_
Missouri
2001 Tahoe door panel removal
At least with my own '01. All you need to do is remove the triangular corner piece on the upper inside of the door (towards hinge side) then (1) hex screw located just under arm rest area, remove this. Then lift up on door panel to "un-hinge" it from metal frame. It has around 6-8 hinges that the panel will re-hook to when putting panel back onto steel door frame. It's basically line up hinges to slotted holes,then slide downward back onto frame. Will have to take out door handle plastic pop-out piece from the panel. the door lock plastic slider switch will also have to be replaced back onto door (last). once inside you'll probably see a clear plastic liner protecting metal door (unless you've already had after market work done (like dynomat) access to speakers is easy from here.
whitehoe01
yep, but for some reason i thought the door had more tha 1 hex screw... ???
im waiting for it to stop raining and i can go take picks as i take my panels off or better yet a video if you'd like but of course it'll take a lot longer to upload a 720p hd video vs pics...
just let me know...
whitehoe01
follow the pics i posted.
i forgot to mention to remove or disconnect the window/lock controls but im sure you know that part
since i can only upload 5 pics at a time i have 2 post for the pics.
Willis12345
