ABS Light wont go off
350VortecSSCT
Westport, CT
:Plugged:ABS light came on yesterday while i was breaking, it was doing the noise and pulling and then all of the sudden the light came on and it shut off...What could cause the ABS to come on? i heard usually thats when drums are bad. Where are the sensors? I am new to braking systenms.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
You could try to clean the sensor. If that does not work then you have to change the wheel bearings which is the whole hub assembly and includes new sensors. They're a pretty penny though.
350VortecSSCT
Westport, CT
Yeah I did 18s with a 285 from a 16s with 265
---------- Post added at 04:57 PM ---------- Previous post was at 04:56 PM ----------
and where is the sensor? i bought the truck with 78k and now has 115k, never serviced drums and dont know where the sensors are.
Bad bow tie
Michigan/NC
There is a wire that is connected into the wheel bearing and the other end is connected to the frame underneath the splash guard. The sensor is on the end of the wire connected to the frame. This is for the front wheels. Not sure where the rear is located. If your ABS light is on, then it is probably the sensor going bad if not the actual bearing. Be prepared to pay $150 + for each bearing. They're not cheap, but easy to replace...that is if you have to. I did mine last year and paid like $330 for both.
---------- Post added at 05:32 PM ---------- Previous post was at 05:27 PM ----------
This link could be helpful if you have to replace them, even though it is for a Jimmy, it is essentially the same process.
http://www.handymanlyness.com/archi...nt_bearing/GM_truck/hub_replace_99_Jimmy.html
GreyFox
Where cars get rusty
or your brakes could be out of adjustment.
But if do go down the route of replacing the wheel hubs. Go to your GM dealership and ask for the bolts that connect/ secure the hub to the steering knuckle there like six to seven dollars each. you'll need six. good to replace them if your car has been exposed to winter and the parts are stock.
hapyspaz
Austin
If I remember correctly, the rear ABS sensor is in the differential housing....
bass1775
Maryland
I found this to be very helpful. However I have a question for anybody out there. I noticed the the calipers on the 1999 Jimmy were dual pistons. Does anybody know if they bolt to the 1998-1999 full size trucks/SUVs. I'm always looking an upgrade and have never been happy with the brakes on my 1998 Tahoe. Most aftermarket upgraded calipers are expensive. I know I'm limited with rotor size with this truck but what about calipers? Just a thought.
Eickybobby5050
