07 Yukon Tires---will they fit???
bonedog
Everything is stock on my Yukon and the current tires are 275/55/20. I have a line on some new Michelin 275/65/20's and wanted to know if they'd still fit in without rubbing.
Of course, neither the dealer nor a tire shop wants to answer that question for liability purposes.
bigbluebowtie
Minnesota
Your current tire is 31.8" tall.
The 275/65/20 is 34.1".
I don't believe with a factory stance this will work.
Turn your steering wheel to where you have the least clearance on the wheelwell.
Will it allow you to add more then 1" of tire (2" taller tire, half of this each side of center)
armandjones82
Banned
If you would try to add up some good parts like what dunlop and other tire brands out there, maybe you can fix it up and make it happen on your vehicle. Try to do that and you might see the difference.
worleytrev93
