Problem with Heat and AC
r33pwrd
Sammamish WA
Well im new to the forum just picked up a nice 07 Yukon Denali a few months back after selling my G8.
So for the first month no problems but I now am noticing that the AC or heat is not working properly. When I turn the Air on it sounds like it is blowing out under the passanger airbag area?? (not much of anything from the vents) if I cycle the hvac (turn on and off) it will correct itself most of the time.
The only thing I have done to the truck so far is a GMX322 and im not sure if this might be screwing with the Can system or if the problem is not related?? (the problem started a few days after the GMX install)
Anyone else has this issue? I do not see any TSB's on it :(
Thanks
zach2011
Platinum Member
Hm. Take out your GMX322 and see if the problem persists.
R
r33pwrd
Sammamish WA
I will try that... pain in the ass as between my GMX322, bluettoth and video cables its kinda a pain to get to :( and the problem is intermitend (sp?) it can go for days without the problem and that have it for a day or two.
JamesinAbilene
