WTF!!! SQUEAKS!!:emotions122:
smkalevra21
Las Vegas
I have been having squeaking coming from under the hood. I replaced my serpintine belt and it stopped two months later i ******* couldnt figure out what it was so i figured the tensioner and assembly went bad. I replaced it and it stopped again for a day. Then it started up again, i check the alternator and everything is fine with the ampage.
HELP ME PLEASE!! What could be wrong its a high pitch squeal sounds exactly like a serpintine belt issue?????
comments?? anyone else had an issue like this?
:emotions122:
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
Turn your a/c on and off and see if it is doing it because of the a/c...may have an issue with the a/c compressor.
Might also be an issue with the power steering pump locking up....just throwing out possibilities.
Pat
Mr45
Florida
How is your A/C working? Compressor clutch slipping maybe?
S
smkalevra21
Las Vegas
Nah i never run my air really even though im in nevada and but i tried both ways and it has no effect and it does not need water to make the squeal sound. I figured on the power steering but soon as i start up the truck also it just starts and sometimes fades away and then comes back later on i have no clue dude i have never had an issue like this.
so irritating to drive a nice truck but squeal next to beater hondas WTF!
rdtahoe
NJ
Pat
Good suggestion.
Also check your idler pulleys in the belt system. I had some on my old BMW that the grease dried out in and began to squeal. You may be able to break it down once you remove them and regrease them with some good synthetic wheel bearing grease.
Good luck.
S
smkalevra21
Las Vegas
Good suggestion.
Good luck.
Thanks brotha but GM sealers the idler pulleys so they can only be replaced. But thats a good suggestion but i dont want to have to buy them unless im pretty sure thats the issue ill check into that and get back to you.
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
have you tried having the hood up and the engine running and just listen to for the sound to locate?
S
smkalevra21
Las Vegas
yeah but id have to get under the truck cause its someone behind the radiator so i cant stick my head in running belts haha i thought about it just to stop the squeal though
Anthony
2004 Tahoe LT (MA)
Westen MA
I having it and it seems to happen more often when it wet outside (rain, puddles, Due in the AM) But sometimes it does it after, I have an 04 Tahoe LT. Its ANNOYING!!!
S
smkalevra21
Las Vegas
Yeah if i put belt conditioner on my belt it makes it about 10 times worse i just cant seem to figure out why the belt thats why i figured it was the pulley system on the tensioner and what not
Anthony
2004 Tahoe LT (MA)
Westen MA
Same here...Put some belt conditioner on it and it jus sequels louder!! I dont wana sound like a POS car anymore! Anyone have any advice PLEASE!
S
smkalevra21
Las Vegas
I have this problem too, I found this thread: http://www.tahoeforum.com/showthread.php?p=95013
What does everyone think? Would changing the (carrier bearings, pinion bearings, ring/pinion gear, seals, etc) and what would be the best way to test whats wrong out of those?
Thanks sooo much for any help!
Yo Anthony did you figure out what your problem was? I dont know wtf is going on with my shit it only squeaks when i start it up i think im going to check out the power steering but i still dont think thats the issue man
Anthony
2004 Tahoe LT (MA)
Westen MA
Im goin' to try to get my Serpentine Belt replaced by next week and I'll report back the results
rdtahoe
NJ
Thanks for the info, I did not know they were sealed units. Good luck with it.
dizhai
