Ultimate 5" Rear Drop Setup
Modded
That Guy
Well I am making this thread just to let you guys know the end results of my rear drop!
I have had just about every static drop on these Tahoe, which are a 2/3, 2/4, 2/5, 3/5.
I just recently installed Bilstein 5125 shocks and all I can say is wow! :shocked:The Tahoe rides exceptionally smooth now, even with 26s. Keep in mind I did not even do the DJM Free Travel Mod, and I do not bottom out much at all anymore.
My rear setups include:
1. Pedders 3" drop coils with stock shocks.
2. Pedders 3" drop coils with stock shocks and shock extenders.
3. DJM 4" drop coils with stock shocks.
4. DJM 4" drop coils with Belltech SP shocks.
5. Belltech 5" 5305 drop coils with Belltech SP shocks.
6. Belltech 5" 5305 drop coils with Monroe Sensatrac shocks.
7. Belltech 5" 5305 coils with Bilstein 5125 shocks.
The way they all ride are rated from worst to best below:
3, 4, 6, 5, 7, 1, 2.
Keep in mind they're may be some error with the Belltech coils rating because I had 24s or 26s with those coils installed. With every other setup, I had 20" wheels and tires at the time. So bascially the Belltech setups have a chance of riding better than the others.
Get these with your 5" drop coils and you will not be disappointed. Max and DJMDIRECT helped me find this setup.:Handshake:
Finalyl done messing with my suspension after 1 year of all these setups.
Also for extra info, I am running factory coils in the front with 1/4 of a coil trimmed off of each coil. Also have Belltech drop struts set at .75" of drop, and 2" drop spindles.
End result is a 3.25/5 drop for the Tahoe.
derk
Saskatchewan
So just to clairify, the best riding setup that you tried is: 2. Pedders 3" drop coils with stock shocks and shock extenders.??
Modded
Modded
That Guy
Yes that was the best riding setup rear wise.
Mainly because it was only a 3" drop and I had 20" wheels then.
R.Beezy
Costco Member
Bay Area 510
so you're saying the Bilstein 5125 Shocks ride much better than the Belltech SP Shocks?? cuz my Belltech's ride well but if you're saying the Bilsteins ride better, i might have to try them out!!
Modded
Modded
That Guy
Way better, not much better!!:Handshake:
These shocks actually dampen, unlike the Bells.
---------- Post added at 03:05 PM ---------- Previous post was at 03:04 PM ----------
With this setup do you have the 1" spacers in the rear? Are you using shock extenders with this shock?
No I don't have the 1" spacer. Also I am not sing shock extenders because my specific 5125 shock was ordered to be short enough to be plug-and-play.
derk
Saskatchewan
Does beltech imprint the part numbers in their springs? I just bought my truck and im wondering what spings are on the hoe.
Modded
Modded
That Guy
Yeah they do, but yours looks like it is the same spring with mine, just the 07 up version, which is the 23323.
The 5305 I have is similar to the 23323, but goes lower by around .5".
HoustonJG
Thanks for the info
I am going to order a set for my avalanche
I am currently using stock shocks with extenders and it rides like crap!
---------- Post added at 08:52 AM ---------- Previous post was at 08:34 AM ----------
Modded,
Do you know which 5125 series shock you purchased?
What are the specs seems there is a page of 5125 shocks to pick from
Thanks
josh
NORCAL SS
SUV SUSPENSION GURU
modded try the djm trailblazer rear spring with djm rear shocks those 2 mated up in the rear (if you can tuck) will be the best ride you got.
Modded
Modded
That Guy
Thanks for the info
Modded,
Thanks
josh
Yes I do, its part number: F4-BE5-6252-H5.
Cheapest on Amazon or Ebay.
And DJM I would run the TB coils, then just pull out 2 of the 4 8mm spacers in my Bell struts, but I would be rubbing all day, I mean I already rub now haha.
If I had 24s still, I would already have that setup, but 26s and that setup will be looking for trouble.
NORCAL SS
SUV SUSPENSION GURU
what size wheels do you have?
with that drop ive done 295 25 26 and the rear djm 5 inch plus kit and its no problem 26x9.5 with 38mm offset
NORCAL SS
SUV SUSPENSION GURU
many local guys dont care out here about it. They want it slammed and want a 26 inch wheel. As long as it fits they dont care. My buddy is west coast rep at nitto they will be releasing a 295 20 26 at sema. it will be the first 20 series tire on the market.
Modded
Modded
That Guy
I have a 305/30/26 with a +35 offset. About 1.5" taller than the 295/25/26 that only Pirelli makes thats also expensive as hell. Also way too thin, but the 107 load rating is proper for these SUVs.
[yt]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/rpec3kLC90A&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/rpec3kLC90A&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/yt]
NORCAL SS
SUV SUSPENSION GURU
we have ****** roads here in san francisco so far out of 13 plus 305 25 26 i havent had one person come back saying there are issues.
Modded
Modded
That Guy
Only ones I have for now, more to come next week.
Jumpshot12
