Porkins
Dead Terrorist
This might come in handy if you have the jumpseat and are looking to replace with a center console and can't find an OEM replacement.
http://www.louish.com/imports.console.html
HOW TO MAKE A CUSTOM CENTER CONSOLE
(Keep in mind there are MANY ways to do this... this is just how I did it. I am not claiming to be a professional at all, I am simply letting people know how I did it since I get asked a lot.)
Step 1, 2 and 3. Making the outline of the floor.
You first need to get the shape of your floor so when your console is done, it lays flush on the floor and doesn't have any gaps under it. So remove the existing console, then get a piece of card board and hold the cardboard vertical/upright to the floor. With a pencil or razor blase, start trying to trace the shape of the floor towards the bottom of the cardboard, then cut it out with a razor blade. You'll have to keep tracking and cutting, until the cardboard lays flush on the floor of the car.
Step 4. Making the top.
Now take another piece of card board and start playing/cutting out a top design... This will be the top side view of the console. (side view as if your standing at the driver side door with the door open looking in the car at the console.) Keep in mind if you put TV's in the front and back, you want to make sure they're at the correct angle.. So when your cutting out the shape, it would be a good idea to have the TV's with you and turn them on and sit in the front and back seat and make sure the angle of the TV is good, some cheaper TV's invert the colors when you look at them at a tilted angle. This is when you'll need to take into consideration your shifter and your emergency brake, and an arm rest if you want one. I have friends who have made it so their center console also holds their AMPS, or Cell Phones, etc... This step is just to make the side view.
Step 5. Making the final cutout of the side view.
Now that you have your outline of the floor and the top, trace them on a piece of masonite. (Masonite is like a hard smooth cardboard, like wood. They use it on top of skateboard ramps to get a smooth finish. Any wood will do, masonite is just nice cause its flexible, smooth, and thin, like a nice quality piece of cardboard. You can get masonite at Home Depot) Then cut 2 copies of the side view out of the masonite... since you'll need the left side and the right side. These side pieces can either be wrapped in vinyl or you can fiberglass these pieces too at the end.
Step 6.
Once you have 2 of the pieces, left and right, put them in your car, with the seats in.. To find out how far apart they should be. Once you find out the distance between the left and the right, you can cut out little pieces of wood to start making the shape. (The front, center and back width might change.. you might need to make the center a shorter width to fit between the seats. This is why its good to use masonite to make the side panels cause you can gradually bend the shape so its closer together in the middle and wider towards the front and back. If you just used cardboard, it would fold instead of bend.) At first.. the little wood pieces you'll be putting in is just to give you the shape, so you can then remove it from the car and work on it. Don't permanently attach the wood pieces to the masonite sides, cause you might have to move the wood pieces later cause it might be in the way of a TV or the shifter or the brake handle. The wood is just to give it the structure and strength. Keep in mind when your putting in your pieces of wood, you need to leave an open square in the front and back for the TV to sit in and mount to.
Once you got the shape, you can now take another piece of masonite (long and skinny) and lay it on top of the console, from front to back. This will be the top surface. To make it smooth when going over a curve.. You can use a ruler and a razor blade to cut thin lines horizontally in the masonite/cardboard top layer.. This will allow you to bend the masonite into a very smooth curve.. You can bend it too, but if you have a lot of crazy curves on the top surface, you'll definitely need to use a razor blade to help you with curving the top layer. Don't forget to make holes in this top piece so your shifter go go in it and the emergency brake.
Then when you have the top layer, and side pieces on.. You can either fiberglass the whole thing, or if you decided to use vinyl before, the side pieces would already be vinyl'd, then just tape off the edges of the side panels and start fiber-glassing that top layer. Once you get the shape of the top and, you might actually want to remove the top piece so you can work with the top piece easier and not screw up the side pieces.. Once the top layer is all fiber-glassed, you can glue the top piece back on the side pieces..
Good luck, if you get stuck or have questions let me know. ( clint at teamlouish dot com ) I do know that it was hard to get the vinyl shift boot cover attached to the console...
Oh yeah.. Cause you have the nail the shift boot cover to the underside of the console.. Our fiberglass kept cracking.. So we had to repaint mine a few times. Then when its all done, you can SLOWLY drill holes to put switches and buttons in the top The actually console isn't even attached to the floor, I can lift it right up.. So mine is a nice tight fit between the 2 seats... So it doesn't move around unless I physically move it. Good luck.
