Stuck on DEFROST!!!
Rockstar
Cant find a vacuum leak. Heat n AC work. But the "blend" indicator just blinks. Befor it would only switch between df dash and floor, wouldn't.
Da90
Tulsa, OK
Mine does the same thing! Find anything out on how to fix it?
riviera rider
when mine was stuck on defrost i changed my climate control on the dash, my rca wires made it short out and you could see it was burnt up in areas since the board isnt covered
Da90
Tulsa, OK
Are you are talking about the switches? I just put new OEM controls in and it still does it! My 97 SWB did the same thing and I also put new controls in it. Still same problem!?
riviera rider
damn them switches aint cheap i spent over 100$ on mine and ive went thru 3 of them lol
Mex-Nali
My '04 did the same thing after I replaced the battery. Thinking something was up, I googled it and on page two I found this gem:
Turn the climate control and the radio off.
pull the fuse under the hood marked hvac/ecas 10 amp in the right side
Leave the fuse out for about a minute.
reinstall the fuse.
******do not touch the c.c. switch when you restart the truck******
restart the truck, the c.c. will automatically reset to 74* and start cycling.
it will take about 1 min for the c.c. to reset itself, you should hear it running through the cycles.
there has been one or two times I've had to go through this procedure a couple of times for it to reset.
Worked.
smoky02
So this is a vacuum problem? Mine blows out of the straight vents but no matter what setting it's on it blows out the defrost also.
fuzzwell
VA
Found this which is the "OIL RESET" but it also reset my vent actuator on my 2005 GMC Yukon with the defrost only working.
Tried the climate control reset, and that did not work. Then this worked:
Turn the ignition to run (one position before starting engine).
Immediately after Step 1 press and release the gas pedal 3 times within 5 seconds.
If the Change Oil Soon light flashes the system is resetting.
Once it is reset: Turn the ignition off and then start the engine to verify the indicator has been reset.
xanatost
Lafayette, La.
:wtf2::signs75: wrong year
mudslinger96
Texas
Try this: under the dashboard next to the gas pedal on the box that encloses the heater core there is a lever sticking out connected to another lever going up. Sometimes the clip holding these two levers breaks of if yours is not connected that is your problem.
Eickybobby5050
