Broken exhaust manifold bolt
BOSS
The People's A D M I N
Dallas
Came across this write up online for removing broken off exhaust manifold bolts. I guess you know what's about to go on in my garage :)
Credit to Chevyboy86 for posting this:
Chevyboy86 said:
this is advice for all the guys in here with head and manifold issues, i used too work in a machine shop for 4 years...just a jobber shop whatever came thru the door pretty much...it was all old conventional machine tools, my boss was an older scottsman been machining for 40+years. i have taken ALOOOOT of broken studs, dowels, bolts out. shaved heads, exhaust manifolds. tons of engine machine work and re-work and re-machine, i.e. shaving heads exhaust manifolds, honing, port and polish jobs, boring...all different types of stuff.
im gonna go on a limb here cuz their is alot of questions asked in this thread.
1.the "fastest" way too get broken studs out is too weld a nut of bolt too them, if they are above the surface...BUT if you are working with aluminum...this can really create problems, sometimes the heat tends too bind the materials together even tighter resulting in pulling the threads out with the stud when it comes or "mashing" them up. the "safest" way too get the threads out (and i realize you cant sometims do this cuz you still got the motor or part still on the truck or you dont got the tooling) is too grind the broken peice flat if you can, center punch it as close too the middle as possible, just start with a ***** punch and you can move it around. once you are satisfied take a center punch and givver a good wack. then start drilling, start with a small drill first (pilot hole) just too make sure of your depth if its a blind hole. then if you have access too a left hand twist drill they work exceptional, most of the time uhoh.gif . if that doesnt work, go until you are at the tap drill size in steps, by this time you should be able too see the crests of the female thread. take a tap, i like too use a "starter spiral machine tap" cuz they arent as brittle, and the spiral flute design really helps you pull the threads out one at a time. once you are done the thread is usually like new unless it was stuck in the first place because some other yahoo before ****ed it up already. thats the way i prefer, especially if its a newer part, and its off of some dudes hot rod than im really carefull with it. i tend too stay away from easy-outs, they can be a nightmare. they are made of a type of high speed steel, they like too break. once you break one off in a hole its a real chore too get them out. usually gotta drill them out with carbide. seems like a lengthy process but its the safest way of doing it welding is fast but its risky...if you got the part out a machine shop should be able too do it for you in no time. alot faster than watching a mechanic doing a machinist job rolleyes.gif (gonna get chewed for that one haha).
2. warped heads or exhaust mani's - again no matter what, ive seen heads come off that were farely new and they were out about .005" - .010". its not a big deal for a machinist too take a little skim off a head for you. old ones ive seen just completely screwed too no return. exhaust manifolds are the same most of the time they are out so much its not even worth it. just buy new ones but its worth bringin them down too a local machine shop too see how bad they really are. cuz if they arent bad it might only take an hour max too take a little skim cut or as one guy said get it surface ground. it all depends on how cheap you are HAHAHAHA.
bringing your parts into a machine shop isnt gonna hurt your wallet by any means its worth a try, they might be able too fix something for you that would have taken hours and write a new curse word bible in a couple minutes with no fuss and a cheap fix. just for all you guys imput. just make sure you get a written estimate!!!!!!!!
BOSS
BOSS
BOSS
Dallas
Apparently it's a big problem, I never knew.
[yt]0yG6WlBNZGI[/yt]
B
hoe
You never knew? lol. My lq9 has 2 on driver side and 1 on passenger. NO codes. quite, and I run the piss out of it. I plan to leave the manifolds and do wye pipe back to tail with 3" pipe.
---------- Post added at 12:41 AM ---------- Previous post was at 12:38 AM ----------
The 5.3 I pulled to replace had 1 broke on each side for a total of 2. Still was quite as shit, no codes.
BOSS
BOSS
Dallas
Here's a great writeup on welding and extraction strategies, if you don't have a welder you can certainly take this printout to the shop and ask them to follow it!
The Art of Extraction
B
BOSS
BOSS
Dallas
Posted by someone, somewhere:
someone said:
My battle is over. I win. I FINALLY got the bolt out today using the carbide 3/16 bit. I cannot believe how easy it drilled into the stud; almost like a hot knife through butter. I then used an easy-out to unscrew it. The headers are on and she's runnin strong right now!
In conclusion:
The broken bolts that were sticking out had about a quarter inch of stud left and I welded an oversized nut to them. They came out very easy. Make sure you use a large, oversized nut so the weld can bond on the most real estate.
The stud that was broken flush was even a worse pain due to its location against the firewall. After removing the firewall heat shield to gain room, I utilized a $130 right-angle air drill and a solid carbide bit ($22). I tried several times to to weld a nut onto the top of the bolt but it was unsuccessful. The carbide bit won it![
B
BOSS
BOSS
Dallas
Ok so tonight I put the tahoe up on stands..I have one header bolt broken off and will be installing some new armor coated Pacesetter longtubes, assuming I can get the stock manifolds off :)
Today I went to harbor freight and got some cool new toys:
-left hand drill bits
-carbide drill bits
-a very short headed air drill/grinder for getting into the tight spots if I need to
-4" cut-off wheels/grinders
-***** punch
-(4) 6-ton stands
So I sprayed some PB Blaster on the exhaust manfold flanges and a tiny bit on the o2 sensors to ease my pain tomorrow. I think I'll turn this into a short write up.
Pray for me... :waytogo:
B
Mac
NY
Take lots of pic on the How to....
BOSS
BOSS
Dallas
Any luck...or big mess?:hmm:
Thankfully I got the broken bolt off with a stud extractor tool from HF and my impact. I will post a picture of the tool I used, it took a couple nights soaking in some PB Blaster, some wacks with a heavy hammer on the head, patience and a few tries with the extractor but that sucker came out!
So truck is headerless ....for the moment :)
B
slocaddy
sarasota fl
so i saw this video and got curious:eek: three broken bolts! might as well buy new heads!: back here in reality ill just be hoping they never leak.
RSymons
Texas
Yep , got one broken on drivers side all the way in the back. Its on a 2005 suburban 5.3 v8
BOSS
BOSS
Dallas
That sucks, I never knew I had one either bc I never looked for it.
Easiest access is to put the truck up on jacks, remove the wheels and the plastic in the wheel wells.
Before you try to take the bolts out, give them a big wack like hell with a hammer to try and loosen em...if you have to, use a punch or a 1/2 drive extension to reach em. PB Blaster really won't get to the threads until you remove the oem headers.
B
alex1268
Antwerp, NY
same problem
I recently attempted to fix an exhaust leak on my 03 Tahoe. On the passenger and drivers side the bolt closest to the firewall was broken off, above level on the passenger side and flush on the driver side, along with another broken bolt on the driver side nearest the radiator. I was originally planning on using the old socket set and removing the stock manifolds and replacing the gaskets and maybe applying some high temp copper silicone.
Unfortunatly i live in Upstate NY where they douse the road with salt. That salt had not only rusted the header bolts to the point of being rounded off as soon as any pressure was applied but the heads of the bolts had been fused to the manifold themselves. I spent many days and night cursing each bolt as it slowly became more and more rounded off. I tried bold out sockets, bolt extractor left handed screws and this weird Drill Chuck looking thing that got a couple of them. In the end what worked the most efficient was to say F it and grind the bolt heads away then a hammer on extractor sockets to turn the bolts out.
I was able to utilize this unfortunate scenario to come up with the reason to buy new Gibson Exhaust headers. LOL. All of the bolts except that drivers side one nearest the firewall broken flush was replaced with Stage 8 locking bolts and copious amounts of anti seize. Also I took the time to replace the plugs with the E3 spark plugs. Also don't skimp on the High Temp Copper Silicone at each connection. Hopefully this can help with increasing my MPG efficiency
afpj
May I ask what you did with that last PIA bolt near firewall?
Da_Hoe
Vaudreuil-Dorion, Qc
Simple. GM uses ****** grade steel. Probably recycled Toyota's. I have extensive knowledge working on Subaru's and I must say that the studs in the heads come out very easily. Cad plated nuts and studs. Makes a freagin difference.
The exhaust ports face down at the road. So yeah, they see more crap then an exhaust header tucked up on top!!! ;)
mikewayne
I feel the best technical way to remove the bolt is to put nut which just fits over it and arc weld the stud, wait until it cools down, then put a wrench and remove the same. Or else used penetrating spray for removing rusts.
mikewayne
Thanks for such a good thread with such a informative things to work with, the thread really seems to be helpful for people trying to work with problems of vehicles all by themselves, as including images as well as videos does work out to be highly user friendly,and without much of technical know how.
dlr2416
I had a bolt brake off today. I found it laying on my driveway then found the right side rear bolt broken off. Anyone have any suggestions for better aftermarket exhaust bolts? I'm planning on fixing the the bolt soon but don't know if I should take it to he dealer or do it myself. Does anyone know if this is covered under the power train warranty and if not how much will the dealer rip me off to do it?
DaUsedMCR
San Bernardino, CA
I had a bolt break a couple months ago... it didnt start leaking until recently. I took it to my favorite exhaust shop, and they charged me $160. I brought them a new bolt and gasket from the dealer, and they removed the header, sanded down the header and the head, and reassembled and put silicon in with the gasket, as well as checked the rest of the bolts and fixed any other leaks I had. A bit more than i wanted to pay, but they are trustworthy and i don't have to worry about it now. They said the header didn't warp at all, but they sanded it to be sure it was flat.
GS Audio
