Replacing shocks
ericnj75
Can someone tell me the part #'s i'll need when i replace all four shocks and rear springs.( Get rid of the autoride having to many problems with it) on a 01 yukon xl Denali.
Modded
That Guy
Just buy literally ANY Denali/Yukon shocks for your make year and model. Doesn't matter where it comes from because you will no longer use Autoride....you can find rear coils at www.gmpartsdirect.com....another good place for shocks is www.shockwarehouse.com, and when they ask for info on your car, input the info like you dont have Autoride!
Your local GM dealer or mechanic can disable the Autoride fucntion or just pull the fuse!
05Yukon
Houston
I would go with the HD bilstiens. You will need the dealer to reprogram it to disable the autoride.
Eickybobby5050
