Leveling kit? which is best?
RLXFXR
Hey!
Looking to lift the 09 Tahoe. Is there an advantage/disadvantage to the Rough Country type of lift/leveling system for the front versus aluminum spacer placed above the front shocks? The Rough Country looks easier to install, but also appears to be make of a plastic. Any opinions/thoughts... experiences??
Thanks for any help!
Andrew
Conor
"Bob's your Uncle"
Seattle, WA
I have not heard much about the Rough Country, but I have heard excellent things about ReadyLift. I think they are probably all fairly similar.
johnny7175
Des Moines, IA
I installed the ReadyLift front spacers on my 2009 Avalanche LTZ and it worked great. The hardest part was breaking the lower ball joint lose.
R
RLXFXR
Thanks, but they're actually quite different in design. One is just a spacer that fits above the shock. The other is a "bracket" that repositions the shock further up the a-arm if I'm not mistaken.
Has anyone ever used the later? Thanks!
UofMZ71
i have the CCM and no complaints so far...
2 E L O
Omaha, NE
CCM 2.5" front 1" rear on my '07... LOVE IT!!!!!!!!!!!
Alignment was off only minimally, ride is same as stock, clearance is much better, and looks killer!
TREYR8D
I'm also looking for the best, most economical leveling kit. The Rough country to me just looks like it applies the spacer to the bottom strut mount with a composite piece. The piece just has one set of through holes, so i don't believe it moves the location. the U shape from what i can tell just acts as a secondary positioning device for the lower strut mount to take some bending load off of the bolts. It also has a very nice price at $65, but no rear lift.
I've seen a lot of people on this forum with the CCM lift, and most everyone that has it seems to be happy with it, and also has an attractive price at $130 front and rear. I've also been looking at the Truxxx leveling kit, which is about $350 with the front and rear.
The ready lift has interested me just for the fact that i could modify the shock characteristics, but it comes at a price. Does the adjustable system work by twisting a knob? or is it an air system that you have to charge with compressed air?
Right now my front runner is the CCM, based on popularity, reviews, and price, but I definitely am doing some homework so i know it will be the best for my application.
2ELO - I really like the look of your truck, I wish i could take off the running boards and molding, but trips up to the Colorado mountains in the winter would chip the crap out of my black paint :( You'll have to post up some new pics when you get your 33s on!!!
turboeclips
Austin, TX
I am doing the same research as you right now Trevor... I am looking to level up my Tahoe hoping to squeeze some 33s in there. I think I remember reading somewhere that the Rough County leveling kit didn't really raise up the front end as much as expected. They do have a 3in kit that is listed under the Silverardo section, but I have seen it on a Tahoe before. Of course the rear end half wouldn't work, but the front is basically the same. On GMFS there was a Tahoe on there with that kit that managed to somehow squeeze 35s.
I am leaning toward the CCM myself. The Suspension Maxx setup looks ok too, but price wise CCM seems the way to go.l
Zed 71
Pacific NW
+3 for CCM. IMO do not install the 3" strut spacer for the front because the CV angle would be to severe.
InTruckDesign
SW CT,
CCM all the way...I have installed dozens of kits for clients and have zero comebacks or complaints.
adp1326
owosso mi.
i installed the truxx 2.5" front and 1.5" rear and am running 305/55-20 nittos. had to trim front slightly. i paid $135.00 at tire rack.
emann_01
I have the truxxx 2.5" front and the daystar 3/4" rear but have not installed it yet....,plan on running 295/65/18 duratracs
Zed 71
Pacific NW
emann, your truck will have the Cali stance with that size kit. That is the front will be higher than the rear. With 2.5" front you should go with at least a 1" rear. I would recommend a 1.5" rear if you tow or load the truck frequently.
emann_01
I thought about this too but i took the measurements from the ground to the top of the wheel wells....passenger side was 3" higher in front than back and the drivers side was 2.25" higher in the front than back
well.....im going to put it on and see what it looks like anyway...can always order the new rear spacers or machine some easily
Modded
That Guy
Wow Emann how do you tolerate 3/4 of Chevy Lean, thats alot more than normal.
emann_01
dont know man...thats just what it came out to be....the truxx kit is actually adjustable to lift 1", 1.5", 2" and 2.5" so maybe i will only put 2" on the passenger side and 2.5" on the driver side
.....you know....now that i think about it the driver tire is about 4 psi lower than the passenger....just havent topped it off
Wakeboarder2MD
Anyone ever put the CCM leveling kit on a Yukon Denali? It is AWD. Would this cause any issues?
NORCAL SS
SUV SUSPENSION GURU
Hey!
Andrew
ive used the belltech front lifting struts give it a 1 inch lift in the front to just level it out with the rear.
JohanZ
