Door lock actuator failure
syndicatesteve
Syndicate Steve
Southern California
Has anyone had their door lock actuators go out?? I have had both the drivers door and the passenger front door actuators go out. Luckily the extended warranty covered them. NOW my passenger rear door lock actuator went out.. DOes anyone know if there is a TSB on this problem. I have been on the phone with GM corporate all week and they refuse to admit there is a problem with them. I am at the point where i just want the last 2 actuators replaced now, so I quit wasting my time. I told them that I was disgusted at the piece of crap units they used during assembly. I did notice on the units that were replaced that they were manufactured by a totally different company.
stss95
I have had 2 of mine go out it seems to be a fairly common problem...
zach2011
Platinum Member
Mine went out on the rear passenger side door.
Modded
That Guy
Exactly why GM is still inbetween a rock and a ****** ass place. Some of the BS that happens on these Tahoes is just straight caused by low quality nonsense, that is exactly why I am getting tired of people shouting Toyota sucks because of all this gas pedal stuff, but yet most of the Toyotas my ents have had have never had useless problems like door lock acutuators going out.
If this problem happens to me I will be extremely mad if they don't replace it......
rogersinsel
I couldn't have said it better. I would much rather die in a flaming car crash or in a pond than have an actuator fail. Seriously, you should consider those that have been killed by Toyoda rather than using it as an opportunity to bash G.M.
nytahoe
"Tha Butcha"
new york
knock on wood im good still. but did break an outer door handle. didnt even give a good yank
Modded
That Guy
Ok Roger take it as you want, I was not bashing GM, just saying!:Handshake:
Certain people on here get there panties tied in a tight knot way to quick, then only come on here to try and bash other members!:mexsmoke:
zach2011
Platinum Member
Lmao Modded, always stepping in when there seems to be some tension..
rogersinsel
I know. I apologize. I kind of tossed fire on it. We all like our trucks, hence why this place even exists. In my experience it is the dealer where you are won or lost as a customer. I have been fortunate in that I have a few very good ones near by. My Tahoe has just over 30,000 and it has been flawless and my 2002 Impala has nearly 200,000 miles on it and has been the same. Both cars have convinced me to never buy a Honda or Toyota ever again. The neat thing is that neither of these vehicles is considered to be the best GM has to offer. Next up, Buick or Cadillac. Lets hope they keep going with their new product.
08denaliXL
Atlanta, GA
same thing
I know I am a new guy, but I could not resist to answer because I had the same problem. My drivers door lock went out (20k miles)and the dealer said they have a new style solenoid to replace it with. The only issue I had after that was the radio/dvd would not turn off after I opened the drivers door when parked. Took it back and the dealer said the new style solenoid required some type of small jumper wire to be added (which they forgot) so the radio turns off when car is turned off and the door is opened.
Mgyver1
Las Vegas
yep, join the club. Do a search here & you'll see several threads on this issue.
Cr8ter
Yep.....I had the same problem. First the drivers at 5K miles then the passenger at 15K miles. Now I'm worried about the rear passenger doors going out. What a pain!
jpmaniac87
Mississippi
Ok, somethings wrong with my passenger, its the whole thing, like it wont even lock manually... is that the actuator, solenoid, or the actual cylinder??
a2t
ATL, GA
ditto. 2008 tahoe hybrid 12k miles, 1 yr old (in service date 6/12/09). drivers side actuator dead, other 3 very intermittent. at dealer now getting them replaced. sheesh...this is piss poor!
they are also fixing trans leak. cant say im impressed.
demonal
My 2008 drivers door went out last week, haven't had the chance to swing by the shop to drop it off, 23k miles... GM and their cheap parts!
rabee
With my 08 Tahoe 24300 M ,I have the same problem, rear passenger door go off , its knock me off,
rogersinsel
I have had both on the driver side fail.
SabrToothSqrl
Add me to the list. Passenger front door actuator replaced at 19,000 miles.
ClovisQ
New guy, but worth chiming in.
Door actuator issue hit me as well - driver's door at around 8k miles. Wasn't sure if it was tied to the fact that someone broke into that door a bit before, but pretty convinced it was just coincidence.
By the way, anyone know the GM part number for the outside handle for a driver's side rear door in chrome for an '08 LTZ? Truck's been broken into twice, and I want to remove the tumbler/mechanical lock to keep the thieves away.
johnbrnrd
Chicago, IL
argh, I would like to join in on the bandwagon with you guys, my sister's door lock actuator also gave way, been waiting for the part to arrive in her home and i'm the one who will install it. why is it that every time I fix a minor problem another one pops out of no where. :Boo:
mfinta
