Jackalope
My transmission is having problems upshifting from 2, and sometimes into OD.
It used to be an intermittent problem, when cold. Letting it warm up, and allowing the RPMs to drop would usually make the tranny "wake up" and start upshifting. Now it is doing it more often, even when fully warmed up. Now when I drive I have to hope it's going to upshift.
My dad seems to thinks it could be the 2-3 solenoid. I've been reading, and some people who have had similar problems have said their TPS sensor was out.
I don't have a CEL, and everything is working fine, idles right, speedo works, ABS works. is it still possible the transmission is throwing a code, even with no CEL?
How do I replace the solenoid? do I have to drop the transmission pan? If that is the problem, and I have to drop the pan, is there anything else I should do/replace while I have it down? The transmission has about 200K miles on it.
any ideas?
any ideas?
