04 2500XL 6.0 pump rub?
2500XL
I've always had Duramax trucks with the 261 or 263 transfer case that had the pump rub issue, but this is my first gas vehicle. Considering my truck is a 2500 from the same generation, does it have the same potential pump rub issue? I have a kit from Merchant Automotive in Michigan that I can get insuralled if the truck needs it, but I'm not sure if the t-case for yukons is a different design or not. Thanks!
at100plus
I'm not 100% sure but I read while I was considering buying an 8.1 that it's only the 8.1 3/4 ton trucks that have this problem.
Mrjvieira
