Marioski's 2007 Avalanche LTZ
Marioski
Marioski
IL
No I find that it's enough space. I don't really like a bunch of "clutter". That's what the center console is for :)
Good to know. I have been keeping my phone in the open tray along with my sunglasses. I like it cause it lays flat and there is room. Might have to scope out a new console once I come back from Colorado this month.
It'll be that or finally pulling the trigger on the Airraid MIT tube I've been wanting.
felixgun
Lafayette, LA
^^^get the tube it's well worth it. Had it on the 08 Tahoe and it was awesome. I'll eventually buy it again for the avalanche.
Marioski
Marioski
IL
Thanks! I plan on duing the tube and one of their dry filters. I wish I just pulled the trigger on it before the trip. Would have been nice to have it to help with some mpg's. Any little bit helps and this winter blend crap is killing my mileage.
Have you run any type of oil catch can on yours?
felixgun
Lafayette, LA
My MPG's actually got slightly worse (about 1-2 mpg's) after getting the AIRAID CAI kit and a BB tune... I thought MPG's would get better too but I was sorely mistaken.
Marioski
Marioski
IL
I don't need the BB tune with the tube, do I?
felixgun
Lafayette, LA
You don't NEED it, but you won't get the tubes full potential without tuning the vehicle to make the cars computer realize it has it installed.
adamjeeps
Felix, how is the ride on your Avy with the leveling kit and did you lift the rear at all? I want to do this but don't need a harsh ride.
felixgun
Lafayette, LA
It still rides great actually. Yea I have a 2.5" leveling kit in the front and a 1.5" spacer in the rear. The leveling kit didn't change the ride quality at all. If anything my toyo mud terrains made the most difference in ride but it still rides great considering they are mud terrain tires.
Marioski
Marioski
IL
I have the RC leveling kit up front (2") and a 1" spacer in the rear and ride quality is the same as well. No issues with AutoRide and Level ride.
Marioski
Marioski
IL
Well I took the Avy in for its oil change and look over before I head out for the roadtrip. Looks like the passenger side cv boot decided to call it a career and start heading for retirement. Had grease oozing out and it was starting to get on the control arms already. Having a new shaft put in right now.
chevyguy_72
That sucks... :sad72:
Marioski
Marioski
IL
I got myself a new desktop background picture! My Avy in avalanche country crossing the continental divide at 11,990 feet. Lets just say my truck does not like this high altitude stuff and steep grades.
Marioski
Marioski
IL
Watch out for the avalanche.....lol.
Lovely
From my CB Radio.
LOL Too funny!
WOW beautiful picture man!!
@Lee - I see what you did there ;)
Thanks Felix. Couldn't miss that opportunity up.
Also put up two short videos (trimmed them down cause my internet coverage sucks out here) of the Avalanche going down from the Continental Divide and then navigating tunnels thru Glenwood Canyon
http://youtu.be/enSQnVBZ_UU
http://youtu.be/SFF0R44Db8g
Marioski
Marioski
IL
Damn.. No one has been on the Avy forums for a while. Time to post up. I've been lurking and busy with other projects. The Mustang, car detailing on the side, moving, a few break downs on the AVY. Finally sitting at work bored so I figured it's time to post up.
Sort after my Colorado trip the front end starting squeaking worse then a teen age girl. So after getting a ridiculous quote from a shop to repair it (they diagnosed it as upper control arm bushings) I decided to do EVERYTHING at once. So I placed an order for a few parts
-Moog Upper control arms
-Moog outer tie rods
(I used Moog as they have grease zerk fittings)
-OEM GM aluminum lower control arms with bushings and a ball joint (time saver.. didn't feel like pressing the old ball joint out)
-OEM GM sway bar bushings
-OEM GM sway bar end links
-NEW drive axles (one was replaced pre Colorado.. did the other one)
The one and only snag I ran into is that with my awesome brute force I snapped BOTH forward upper control arm bolts. Okay they were frozen inside the shaft of the OEM UCA and just sheared off. Some grade 8 bolts were used as a temporary fixed while I ordered replacements thru my local dealership.
Now lets fast forward to end of May / early June. All of a sudden I am developing some weird ass vibration thats coming from the front. My first logical thought, wheel hubs. So of course I run to the store and order up some brand new MOOG wheel hubs
Glad I did cause this is what I found when I removed the old one - a burnt thru and overheated ABS line which tells me the hub was running hot.
HOWEVER.. That did not fix my vibration or noise. At this point I have new hubs and new cv joints. I craw under the car and notice one of the cv joints has grease splatter on time. Oh oh.. it's new (under lifetime warranty). I also noticed the inner axle stub shaft (drivers side) is wobbling around like crazy. After placing a few calls to some driveline shops, I have found out that these 9.25 GM IFS units are prone to failure and mine is probably starting to fail. Out it came
It actually took about an hour to remove and I was surprised how easy it was. It was also an hour to install and with two jacks it's a one man job. My turn around time was 2 days at the shop and $600. It was fully rebuilt with all new bearings, seals, etc. The ring and pinion was fine as I caught it in time. What failed was the adjuster on the drivers side the locks the gear in place and adjusts the play. Basically the ring gear and carrier were starting to wobble around inside the case. Here's how much crap was inside the oil when I remove the drain plug
So as it stands now, my entire front end is completely rebuild other then the driveshaft u joints. Hell I'm thinking about doing those just for good measure.
Oh and in case anyone is wondering. No humming... no nose... no vibrations... I'm one happy camper now.
NathanJax
Vacation Nathan
Jax, Fl
Wow... you're getting close to a new drivetrain... I'll be PMing you when it's time to change mine. How would you like a "vacation" to Florida? :pepper:
dizhai
