Tying to hide a sub in a 2dr Yukon...
gulleyman
TX.
Okay so I'm trying to figure out where to hide a 10" sub in this thing and I'm calling on you experts here in the forum for some input :help:
I saw a post here where someone put one in the rear passenger quarter panel that looked pretty clean but he had a Solobaric. I am going to need a little more air space to put a JL 10" back there.
I've also seen these by Q-form but they're SO expensive. Anyone have any experience with these?
Has anyone seen a factory sub and trim panel from a 4dr like this one in a 2dr?
Let me know what you guys think, any input will be appreciated :hmm:
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
I would also like to know. I'm getting rid of my two 12"s. I want my cargo space back.
Also, I'd like to know where to stuff the amps.
gulleyman
gulleyman
TX.
I'm in the process of laying all of that out right now. I have a big 5ch amp I was going to use to power the whole system but it's so wide :doh2: I can't find a practical place to put it without hacking up my truck or building some elaborate rack. I want my set-up to be nearly invisible.
So I dug a couple of old 2ch amps out of the garage that haven't seen daylight for a loooooooong time. They're made by Linear Power, only 10"x10", super powerful and have ridiculously low distortion ratings. They don't make'm like they used to, lol.
I discovered that there is a pretty decent sized space behind the panels to either side of the back seat that I can mount them both. There's room for them to breathe so they shouldn't overheat plus you only have to take out one screw to remove the armrests; which will give me access to them once the panels and seats are all back in. Very convenient location for me and almost impossible for a thief to get at in any short period of time, and totally invisible just the way I like them :secret:
I'll try to get some pics up for you guys later tomorrow.
gulleyman
gulleyman
TX.
Here are the pics of the installation, not the prettiest install I've ever done but it's definitely the stealthiest.
I was almost finished but I goofed and bridged the wrong amp :emotions122:
One of them is 2ohm stable but it's not this one :doh2:
So now I gotta take it to be repaired today and hopefully put it all back together this weekend. Oh well...
grimm
Bay Area, CA
Good stuff gulleyman. I'm in the process of trying to figure out how I want my sound system to be set up (Since my OEM head unit finally died... 13 years of good tunes though, not bad). I'm replacing the head unit, all of the door speakers and the rear deck speakers too. I want to power my speakers with a decent amp rather than just off the head unit. I was going to go with out any subs because I don't want give any one some incentive to snoop around my truck or break in, especially in my neighborhood. And I still need my cargo space/seat foldability in case I need to haul some shit or if I want to sleep in it while camping.
Now I have some ideas as to where I can hide my amplifier(s) should I go that route. And now I have some ideas for stealth subs too (but I'm still a little iffy about running any subs). Thanks for the ideas man.
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
you could build the box through the floor (close)behind the back of the rear seat as long as your not lowered. thats why i went with rear quarter (1st pic) i also had a jl 10 w6 in that box flipped with magnet exposed and it sounded ok but it defeated the purpose so i put a solo classic i had .i like where your putting your amps but think about some cooling fans in there.keep posting your progress looks good
gulleyman
gulleyman
TX.
Thanks, I think your right there. I already had one casualty, I have taken the amp to three shops already and no one wants to touch it because it's so old :bawl:
Just another good reason for fans....
moviewithnotitle
Jersey
gulleyman,
I did this install of the amps just like you did about 4 years ago. To combat the heat and ventilation issues, I installed a small fan under the cup holder. I also drilled some holes in the rear area where the panels meet. I have not had any heat issues so far, and I do pump the system hard from time to time. Both my amps (kenwood's) have internal fans as well. Not sure if this makes a difference, but it shouldn't be too big of a deal for your's. Old school amps are built like rocks.
I'll try to snap some pics in the next day or so but here is a link to the type of fan I installed.
http://www.google.com/imgres?imgurl=http://www.traderscity.com/board/userpix11/6175-dc-brushless-blower-fan-1.jpg&imgrefurl=http://www.traderscity.com/board/products-1/offers-to-sell-and-export-1/dc-brushless-blower-fan-27689/&usg=__ffR15M5m5sC3PaYo_Hswfxe8W1I=&h=300&w=300&sz=10&hl=en&start=59&um=1&itbs=1&tbnid=F6KQxaSE63rJmM:&tbnh=116&tbnw=116&prev=/images%3Fq%3D12v%2Bfan%26start%3D42%26um%3D1%26hl%3Den%26sa%3DN%26ndsp%3D21%26tbs%3Disch:1
moviewithnotitle
Jersey
Here ya go...
Fan mounted in the cup holder... (I used a hot glue gun for this. I also added a little screen for protection from debris)
View from the underside of the cup holder (you can see the amp here too)
View of the holes in the panel for drawing air into the area. (you really don't even see these holes unless you look)
As for where to source this fan, I would think Partsexpress.com or probably Radio Shack. A good Car Audio shop should also have these as well.
I run the fan off of a relay off of the ignition so I know it will come on with the key. I also made sure that this circuit was different then the amp-turn-on-relay I used from the stereo so that I wouldn't induce any noise. (these fans can induce some really high-pitch noise when on the same circuits. The fan and relay are cheap, your talking about $20 with all the materials.
If you have more questions, just ask.
MWNT
gulleyman
gulleyman
TX.
:hail: moviewithnotitle, that is freak'n AWESOME! I so gotta do this, thanks for posting this! How thick is your amp? Wonder if mine will fit with the fan...
moviewithnotitle
Jersey
Not sure on the thickness of the amp, but I would guess about 2-2.5". You should be able to squeeze a fan in there somewhere, or angle it out some other way. If you have clearance issues, I say bust out the dremel and get creative!
soco707
can you tell me the dimensions of this box and did you have to cut any metal or just the plastic trim panel
moviewithnotitle
Jersey
While I don't know the dimensions, I would guess that you would get about 1.0 cu ft out of that area. Maybe a schoche' more if you used fiberglass for the backside. Under the rear seat is a more usable area while still keeping it somewhat private. And if made removable, the rearseat is still functional. Sundown Audio makes some 8-10" subs that don't require a lot of space either. Could easily fit in a lot of tight spots. You just have to get creative.
Ventura139
I know this post is a few years old but I’m looking to do something similar. But instead I’ll be playing a lithium battery in there. But I’ll most likely be leaving the side panel off instead of hiding it. What’s the best way to remove that panel? And certain order
Thanks
bigdog9191999
sw michigan
Thanks
there should be tons of youtube that walk through step by step for taking them off. it will look pretty naked in there without the panel on at all.
JPeter
