View Full Version : Guys guys look :p
DJTricky
01-24-2010, 08:04 PM
i just got back from dyno :P i love my numbers haha
check it out
dyno pull #1 = hp 437 on 87
dyno pull #2 = HP 459 on 91
-stroker 383 with forged internals (10.5:1)
-high flow CSFI Vortec Spider
-full blown motors twin fuel pump set up
- 2 X 255 fuel pumps (walbro pumps)
-comp cams mild street cam
-CFM-Tech Ported Throttle Body
-CFM-Tech High Flow Throttle Blade
-ported heads
-2.5 inch cross over pipe
-hollowed out cats
-gasket matched exhaust manifolds
-4 inch aluminum intake
-MSD ignition system (msd 6AL)
-MSD distributor
-MSD 65,000 volt ignition coil
-MSD 9 mm plug wire
-E3 diamond fire plugs
and just to back it up. (2nd gear pull)
http://i23.photobucket.com/albums/b379/DJTricky/tahoefullblownmotorsports.jpg
AtomicHoe094
01-24-2010, 08:10 PM
what happened with your trans before when it was all fucked up>? i like those numbers too. What yrs your truck?
DJTricky
01-24-2010, 08:19 PM
my 3rd and 4th clutch packs were destroyed. but yeah i love the numbers. haha he said if i REALLY wanna get some power. let him build my tranny and do a full dyno tune and timing set up. for 5k total i think i will buy a new tranny and get a black bear tune for cheaper
edit lol my truck is a '96
AtomicHoe094
01-24-2010, 08:35 PM
5grand for a build and a tune? sounds crazy to mee.
TIM Z
01-24-2010, 08:51 PM
Thats A healthy small block!
RwTQ ???
So your trans is bad?
If so youve got power on the table.
How bout a pic of your engine.
DJTricky
01-24-2010, 09:11 PM
yup he wanted 5 grand for a new tranny and a tune. i can get a monster tranny for about 1500 and a bb tune for about 350. so i told him no on that.
my rwtd was 501 on 91, i will see if he can send me the dyno graph of the torque curve. he might need me to make another pull :/
she is a little dirty but at this point this is the best i have right now
http://i23.photobucket.com/albums/b379/DJTricky/Mobile%20Uploads/Photo-0054.jpg
TIM Z
01-24-2010, 09:48 PM
Damn 500 TQ .
Thats FN stout!!
So you still need a tune???
JennaBear
01-24-2010, 10:01 PM
Don't forget to minus the 20% for the DynoJet factor. Not bad though!
EDIT- looks like you have some issues in your HP/TQ bands, did they give you any other print outs. Are you sure it was 501TQ? You should be close to if not over 500HP if that is the case.
Redman7
01-24-2010, 11:00 PM
Justin is a lucky man. Nothing sexier than a woman who talks horsepower and torque ;)
JennaBear
01-24-2010, 11:01 PM
:mwah1:
DJTricky
01-25-2010, 12:56 AM
true that he is lol but i cant get a really accurate dyno pull until i get that tranny fixed, if i go WOT in 2nd gear it pops out into first :/ so that pull was made in first and i tryed in 2nd but it didn't work :( and it slips
95TwinTT
01-25-2010, 02:46 AM
If you are doing a dyno pull in 1st gear on a 4L60e, I think you have to divide the results by the gear ratio, or 3.06 :1
The dyno's are expecting a pull in 3rd gear or 1 ro 1 ratio.
If you did pull in 2nd gear, divide by 1.65
They also generally track torque along with hp. 5200 rpm's is where they should cross.
Sounds like you are having fun though. :)
foreverfalcon40
01-25-2010, 09:18 PM
JESUS F/'N CHRIST! GOOD FOR YOU!
I HAVE ALOT OF WORK AHEAD!
Hope I get close to 400 with my S/C set-up.
---------- Post added at 09:18 PM ---------- Previous post was at 09:18 PM ----------
I stop at 500hp is good for me on a DD anything after that I would get a new DD which is what I plan to do.
Justin
01-27-2010, 05:51 PM
Transmission gear is irrelevant, as there is no such thing as a 1 to 1 ratio. You still have gearing occurring at the differential as well as the tire diameter to roller diameter. The tach reference must be established, either via induction pickup (dyno then computes hp based on roller speed relative to engine speed) or derived via tire height at xx rpm.
Dynojet operators tend to use 3rd gear because it allows a much, much slower ramp rate on an inertia dyno than 2nd gear would. On a loaded dyno, it does not make any difference. I use 3rd gear (or 4th on a manual) only when the tractive effort (torque multiplied by gearing) is high enough that it wants to climb off of the rollers.
95TwinTT
01-27-2010, 08:24 PM
I have to say, your off the reservation on this one.
I have never heard of any serious horsepower or torque information being considered that was not acquired from a dyno running in the 1 to 1 rpm range, meaning one revolution into the trans to one revolution out.
Granted there is a gear ratio for the rear end and tire sizes to consider, but they are real time, real world scenarios that are always the norm.
I know there are other applications for solving drive-ability issues, like holding specific speeds under load, but I would like to know what dyno establishment uses first gear for a normal test.
DJ, was just having some fun but his tranny was fried, so he didn’t have 3 and 4th gear. Tell you what, lets wait until DJ gets his tranny fixed and then see if he gets the same results in 3rd gear on the same dyno. We are in the same town, so I can go sit in on the test.
That would prove that you are correct if he hits 500 hp. :)
TIM Z
01-27-2010, 09:11 PM
I have to agree, ive never heard of final dyno results bieng done in 2nd gear.
Justin
01-27-2010, 09:52 PM
IF I'm so wrong, do tell me how, mathematically, don't just spout about how things are done this way because that's the way they've always been done. By that logic, we should still be sacrificing virgins to appease the Gods.
Dyno development of tunes is an integral portion of my business and I have tuned vehicles in second, third and fourth gear with comparable results.
Now, with this DynoJet dyno, chances are you will see differing numbers because of the lack of capabilities of such a simplistic unit, but it has nothing to do with the gearing of the transmission, it's entirely due to the rate of acceleration of the roller. Strap it down to a dyno dynamics or mainline, set the engine ramp rate to an equivalent value for both 2nd and 3rd gear, you'll see comparable results. Tractive effort (force applied at the tire surface) will be significantly different between the runs, but engine power will be comparable.
Here's some more reading material as well:
http://www.factorypro.com/magazine/dynojet_dyno_inflated_hp_reason.html
95TwinTT
01-27-2010, 10:18 PM
I’m sure you do a great job of tuning in different gears, but not at wide open throttle. Maybe you could start a new fad. It would save a lot of wear and tear to not have to run the vehicle up to 130 mph. You could keep the pulls under 40 mph.
We should hit the pause button here and wait until DJ has his tranny back together. I’m sure he would be more than happy to try again.
As you say, this may be a “simplistic dyno” and may offer differing numbers. If so, it probably is also not able to set up for a first gear pull.
Either way, I’m in no hurry. We can wait until then. Keep your powder dry. :)
Justin
01-27-2010, 10:40 PM
Actually, I do tune in 2nd gear at WOT on all trucks under 450rwhp (due to tendency to climb off of the rollers). Running an extended cab pickup at 6000rpm in third gear is just asking to throw a driveshaft. If anything, I will often dial in part throttle from 1200-2400rpm in 3rd or fourth to reduce the tractive effort and yield a smoother operation, then lock the torque converter and command 2nd gear for wide open throttle, running from 1500rpm-redline over a 4-5 second span of time (typically). That said, I usually don't care at all about the numbers shown, I tune til the point of optimization and focus more on any percentage change than anything else.
The DynoJet can handle first gear just fine, the problem is that since the ramp rate is not controlled (the simplistic aspect), the engine will tach out in a second or less as the roller speed needed for 5000rpm is very low. Since the dynojet "measures" power based on acceleration, this shorter pull has much lower resolution than a longer, higher gear pull, which may contribute to variance, especially if the RPM reference is taken from wheel speed at a fixed reference point.
Nickleahy23
01-27-2010, 10:51 PM
:hands:
95TwinTT
01-27-2010, 11:26 PM
You keep talking about climbing off the rollers, are you referring to a Mustang Dyno?
It would seem to be difficult to walk off of a DynoJet. The drums are huge.
“Since the dynojet measures power based on acceleration, this shorter pull has much lower resolution than a longer, higher gear pull, which may contribute to variance , especially if the RPM reference is taken from wheel speed at a fixed reference point.”
So, lower resolution is your way of saying “not as accurate”.
I couldn’t have said it better myself. As I mentioned before, I do not mind waiting for the results from a 3rd gear pull. I can come back and bring up this thread with the results when we get them. OK? :)
Justin
01-27-2010, 11:44 PM
I have stated load bearing since my first intro here (dyno dynamics, mainline, mustang, etc), as a dynojet is useless for anything other than wide open throttle. Anybody tuning professionally that is concerned with drivability will do so with a load bearing dyno.
Lower resolution simply means that if it takes 100 samples a second (for example) and calculates hp based on that data, there will inherently be less accuracy when a 1st or 2nd gear pull takes significantly less time than a 3rd gear pull.
As far as comparison's go, they'll be worthless unless you're locking the torque converter as well, as a rapid 2nd gear acceleration will yield less of a flash than a longer 3rd gear acceleraion will.
95TwinTT
01-28-2010, 12:29 AM
Well, you have brought up about all the reason’s I would have for why the 3rd gear pull will not be the same as the 2nd gear pull.
Now all we have to do is wait.
Thanks for taking the time to verbally Joust with me. I do enjoy these chats……….
I’ll light it up again, when DJ does the 3rd gear pull……………:sleepy10:
Justin
01-28-2010, 08:52 AM
The only reason that has been postulated is because the capability of the dynojet is in question, mathematically, there is no difference.
haks310
01-28-2010, 01:11 PM
Tricky....fix your tranny.
foreverfalcon40
01-28-2010, 01:21 PM
After this...if I was him I would be afraid. lol
What all this talk...I ask this.
When the weather warms up and I slap on the Whipple I plan on going for a Dyno Run and Tune.
What would be the best dyno to do so on?
JennaBear
01-28-2010, 11:21 PM
Are you just looking for numbers? If so, a DynoJet will give you the highest numbers.
If you are tuning on a dyno, you will want a load bearing dyno.
foreverfalcon40
01-31-2010, 12:17 AM
Thanks Babe...I would love for Justin to get his hands on it. I'm using Justin's tune to hopefully drive the Hoe from my driveway to the shop for over look of my work and dyno and tune. Just hate for it to go KABOOM. Wish you guys were coming to NYC or somewhere near closer. If I get dyno sheets from the dyno can Justin tune it from that? What can I get from the tuner to help Justin do it.
Go BB or Go Home
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
