Auto Dome Lights
Davyboy
Alberta, Canada
They don't turn on when doors are open, do you guys think this is a short, if so where do you think it would be?
99Yuk
Northern Ontario, Canada
I'm gonna ask a dumb question here, have ya checked to make sure that the override button is not pushed in? If you have checked, sorry for asking.
MtnDewd
Northern Colorado
That happened to me once after the wife had driven the hoe. I checked the fuses etc to find the over-ride button had been pushed in.
James909
The door switches may be worn out. When I bought my truck both switches didn't work. If I wiggled the pin the light would come on. I replaced both switches and that fixed the problem. Does opening the tailgate or turning the dimmer switch all the way up cause the light to come on?
D
Davyboy
Alberta, Canada
Turning the dimmer switch all the way turns all the lights on, however opening either door does nothing.
Where would one find the switches to replace them?
James909
I attached a picture with the door switch circled in yellow. They're only like $6 each and really easy to replace. Just reach behind the dash and there are two clips on the switch that you need to compress and then just pull the switch out of the dash. I found it was easier to disconnect the switch after removing it from the dash.
D
Davyboy
Alberta, Canada
Where can you get them, I knew which they were, (thanks for the pic anyways, super jealous of how 'clean' your interior looks, way nicer than mine atm)
riviera rider
my drivers side door does this, but yet when i open any other door the lites come on haha im not too worried about it right now ill fix it over spring
ravingmadman
Chief Knuckle Buster
Greater Seattle
I'm going to threadjack. So one of the prior owners was a total creep, and removed the door switches so neither the front doors turn on the light. The rear doors turn on the light. They also removed the inside door handles in the back, and installed poppers, with the only buttons up front. So once in the back, you're stuck. Creepy.
Anyway, can someone take a quick picture of the switch in a '99, and where the wire goes from the switch? The whole thing is missing from my rig, and I'd like to hook it back up.
D
Davyboy
Alberta, Canada
The switch should be just in the same position, just look for a spot on the side where the door would close against, its very similar with my car as well, so you should be able to find it easily.
JamesinAbilene
