rigo_jones
going against
anti-theft save your truck from getting stolen
Theres been a lot of threads about good people getting their truck stolen. I've been there myself so many times that i decided to do this.
I'm sure some of you know this but some dont and I think this works better than a clubstick or a simple alarm. It will take you about 20-30mn depending on knowledge but is simple to do. I've had 2 hondas stolen and 1 that they tried to take but with this mod they couldn't.
First what a thief does(did to my cars) is see if it has alarm... obvious if it does he will go to the front of the car/truck, there he will look for the hood latch cable cut it, open your hood and disconnect/cut the battery cable. But wait, you have a hood trigger sensor. Well a good known thief will need less than 5 seconds to pop open the hood and quickly cut the battery wire. Now say they cut the wire and alarm will deactivate but some good alarms have a relay that activates if the alarms power was cut, and when activated so if they plug the battery back the truck will still not run because the alarm has the relay activated.
But of coarse any thief knows that so they look for the alarm and gut it before connecting the battery back. Now all they got to do is break the ignition switch some how and drive off. This happens in less than 3 minutes, less if theres more than one thief. with this mod the car/truck will not crank even if they cut the battery, change computer, gut the alarm or brake the ignition switch.
You will need a switch that is rated to equal or more of the amps of either the fuel pump or crank fuse. You see where I'm going with this?
Find the fuse that disables the fuel pump or cranking. Our GMs only have a fuse labeled crank this should do it. For any manual transmission car/truck use fuel pump fuse.
You can find a fuse holder like this or just splice your harness. Make sure you keep a fuse in line with the switch in same size as oem.
The last step is to find a hiding spot for your switch. Make sure no one can see you activate it not even friends/thief
. Usually is best somewhere where you can activate it with your foot.
Thats it!!!
Keep in mind that if you have remote start, this will prevent your truck/car from starting if switch is activated. But you can always activate it in an unknown area to you.
---------- Post added at 05:59 PM ---------- Previous post was at 05:55 PM ----------
btw I had 3 of these on each of my hondas deactivating the fuel pump, ecu, and distributor. But you only need 1.
. Usually is best somewhere where you can activate it with your foot.Thats it!!!
also is there a way i can fix the title?
