View Full Version : Rear tires rub with 24s.
Murderedouthoe
05-20-2009, 02:34 PM
I have 24s on my 07 tahoe and every once in a while when i go over bumps or around tight corners they rub the inner fender. I have cut a little where it rubs but i dont want to tear the whole thing up. Does anyone have any other suggestions?
road1will
05-20-2009, 03:08 PM
Lift it
Murderedouthoe
05-20-2009, 05:43 PM
no thanks, that would look horrible. Its already to high as it is.
jmildoc
05-20-2009, 06:12 PM
looks really high now how does it rub?
Nickleahy23
05-20-2009, 06:36 PM
mine rubbed in back as well...give it a week or 2 they will rub the plastic enough to where it doesnt make any sound..it wont hurt anything either
road1will
05-20-2009, 06:43 PM
It was a joke. :emotions122::emotions122:
Conor
05-20-2009, 07:28 PM
What is your offset on the wheels. If anything should rub, it would be the fronts. My Momo's rubbed a little in the front of my Escalade and I had to cut some of the fender liner out.
Murderedouthoe
05-20-2009, 09:12 PM
Im pretty sure its a 40mm offset, It only rubs when the shocks compress. Like when im towing a boat so it would take a while for it to wear down.
road1will
05-20-2009, 09:13 PM
Is it when just one wheel compresses or both?
I would space the wheels out, start with 1/4in. and see how it goes. Doesn't sound like you need much. My rears are 1/2in. spaced out and made a big difference...problem is I already cut out alot of plastic and now I gotta go buy a new set.
BOSS
DwDrummer
05-20-2009, 09:26 PM
If you have the Boss 330's in 24's you have a +30mm offset, I have the same wheels!:)
road1will
05-20-2009, 09:32 PM
You can get wheels in different offsets.
Murderedouthoe
05-20-2009, 09:43 PM
No they are 313s, and i have thought about spacers i dont even think i would need 1/4 inch. It barely hits, just enough to make noise.
Nickleahy23
05-21-2009, 12:11 AM
its not that big of a deal..i mean ya it sounds annoying as hell..but mine went away after a week..worst case pop the wheels off and trim exactly where its hitting
Murderedouthoe
05-21-2009, 01:14 AM
ya, really annoying. Thanks
DwDrummer
05-21-2009, 08:47 AM
This I know but for the this particular style ( Boss 330 ) wheel it's available in only +12 and +30m for 24x10 in the 6x5.5 bolt pattern. The 313 was offered in a +40mm.
Murderedouthoe
05-21-2009, 10:42 AM
the boss 313s come in a +12 and +40 offset in the 6x5.5. Thats why i said i thought it was a +40.
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
