performance inspired colant overflow tank's
DJTricky
Banned
Robbinsdale MN
yes i said TANK'S :p
i got tired of looking at that ugly milk jug of a coolant overflow tank, so i did this.
my list of parts
2 overflow tanks from jegs
http://www.jegs.com/i/JEGS/555/511000/10002/-1
2 tank mounting brackets
http://www.jegs.com/i/JEGS/555/511020/10002/-1
2 brass "T" fittings, size 1/4 inch ID
some 1/4 inch ID coolant line
and some 1 inch " L " aluminum
and got to work :p
AND THE FINISHED PRODUCT (ready to be cut off and mounted to the firewall)
syndicatesteve
Syndicate Steve
Southern California
Here is my solution to the ugly Radiator overflow tank. I had it made out of Stainless Steel and then painted and air brushed. I did the same for the Brake fluid reservoir.
more pics in my album.. check them out
---------- Post added at 01:28 AM ---------- Previous post was at 01:27 AM ----------
if you go to www.killerglass.com, they have a pyrex glass overflow. it is a universal fir but its pretty slick and has led lights inside.
D
DJTricky
Banned
Robbinsdale MN
im actually waiting for my race tube to come in from my sponsor, i will be putting in my own blue led's(there 3 times brighter)
AtomicHoe094
Atomichoe094
cleveland, OH
nice.. when your mount the alum bracket to the firewall, make sure you have some grommets or rubber washers inbetween the alum and steel as it will corrode and shit. looks alrite, im going with the stainless steel tube Flexalite sells to mount directly on the radiator it self, so none of that hose crap laying around
D
DJTricky
Banned
Robbinsdale MN
there will be rubber washers between, but im also goign to be using the same location as the stock. so the same bolt holes will be used. shit if there is space i might even pick up a 3rd. but idk yet.
blackcoffee
O.G. Black.
Ok these look cool and all but.. It looking like a milk jug serves a purpose. It's see through.. So you can SEE the levels of coolant.
D
DJTricky
Banned
Robbinsdale MN
true that, i have a way around the not being able to see into it, but i have to wait for some more fittings and such.
here is the finished and installed product.
lets start with the fab work :p
due to the jugs hitting the hood i had to drop and stagger the brackets.
FINAL INSTALL
so? what do you think?
Davyboy
Alberta, Canada
Those look awesome, how much did everything cost you?
And the title says performance inspired, how would this affect your performance?
And as a couple comments were made about seeing coolant levels, how would you overcome this?
D
DJTricky
Banned
Robbinsdale MN
i said performance inspired because most of the race cars/sprint cars i have seen have 2 or 3 tanks, called catch cans, because its not good to spill liquids (oil, coolant, and others) on to the track. it does not affect performance, just to me looks better.
and as for seeing the coolant level. im waiting for my funds to come back in, so i can buy a couple more fittings to run a clear high temp PVC hose up one side of the 2 tanks, as the tanks fill so will the clear hose. at the same level.
and yes they have clear radiator hoses. but there not to good. if you get a solid hose, it does not allow for engine movement, they look cool, but are also prone to leaks and the led's short out causing electrolysis in your coolant and causes the radiator to plug up, my friend had one for his scion xB, but im going to buy there "race tube" and thats only a like 4 inch clear insert that you can see your coolant flowing.
JohanZ
