PDA
View Full Version : factory nav and music at the same time?
chadman
12-13-2009, 10:06 PM
I know this is a dumb question, but I don't have a Tahoe yet.
Can you listen to music and have the navigation going at the same time?
kses123
12-14-2009, 12:37 AM
Yes, you can. However, if the Tahoe is '05-'06, you cannot be using navigation while listening to a CD. You can listen to anything else. The is because it has no external CD drive like a Denali/Escalade. The 07+ Tahoe's have the ability to listen to a CD and use navigation because they have two drives. But, no matter what year, you can still listen to music, etc.
jdpromo33
12-21-2009, 11:42 AM
I have this same dilema on my 04 Factory nav.
Is the only option to replace the unit with aftermarket one or can you add external CD drive to exisiting factory nav?
kses123
12-22-2009, 04:51 PM
You can add the OEM denali/escalade 6 disc changer to yours.
This should give you an idea of what it would look like. It's not hard to install or wire up either.
http://duramax.onlinedesk.net/navinstall/
jdpromo33
12-22-2009, 09:32 PM
My truck already has the nav system and lux amp so I just need to add the 6 CD changer but not sure where to wire it to
JD
kses123
12-23-2009, 12:27 AM
JD
Look at that site I posted earlier. It tells you where to.
phileaglesfan
12-25-2009, 07:46 PM
I plan on getting an Ipod and dumping XM. You can burn all of your CD songs to your Ipod. A remote 6 disc is so old technology.
