View Full Version : Loose rattle sound in the front end
rms25thta
05-15-2009, 02:07 PM
Has anyone had a issue with a loose rattle sound coming from the front end in their Tahoe?? My 02 has it and happens when I go over a bump especially at slow speeds. Just wondering if any of you have any insight.
Rich
Shaggy
05-15-2009, 11:02 PM
Have you checked the bolts to the front bumper to see if they are loose?
rms25thta
05-15-2009, 11:03 PM
um.....not the bumper.....it is the intermediate shaft in the steering I found out.
fatnlowtahoe504
05-16-2009, 03:25 AM
what part of the shaft is that? i have same problem and i have steering problems too, its hard to turn it to the right only like there is no power steering and then its totally fine to the left
rms25thta
05-16-2009, 08:20 AM
I don't have any issues with turning, that sounds like your steering box. Mine just rattles when I go over bumps like I have a loose component in the front end but it isn't. It is the intermediate shaft in the steering. Do a search for it over on gmfulllsize.com there are tons of post about it.
Volant1
05-16-2009, 09:47 AM
There was a recall on the older year tahoes steering shaft, If you here a loud pop at max turn, you need the new shaft. I can give you the autozone link if you need it
Big Tap
05-18-2009, 06:04 PM
There is a whole thread about it here on this forum. Pretty common problem.
http://www.tahoeyukonforum.com/forum/showthread.php?t=642
TMoNeE
05-19-2009, 01:40 AM
think i have this problem on my escalade
tybardy
05-19-2009, 03:26 PM
i have a rattle EXACTLY like that and it is NOT the int. shaft.
Going over bumps never seemed to effect my bad shaft (yes i had that problem too) however there are also some weak points in the font suspension.
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
