PDA
View Full Version : Challenge: Put this together for a Tahoe!
BOSS
05-15-2009, 09:18 AM
Who can tell me how to build up a Tahoe to sound like this!
s2rKmw2DDZY
Has to be one of the best cams I've personally heard...here's what he did so far:
American Racing 1 7/8 headers
3" catless mids w/X-pipe and 3" stainless dual exhaust
Magnaflow mufflers and 3 1/2 Double wall tips, Dart 225cc Heads
Ported Victor Jr. w/elbow
Ported 90mm Throttle Body
Edelbrock Fuel Rails w/42# injectors
Underdrive Pully
Melling oil pump
Double roller chain
MSD 8.5wires
Comp Cam Hyd. roller XER Lobes
Trickflow pushrods
Trickflow Double valve springs,
locators
titanium retainers
locks
ARP Head Bolts
BOSS
jmildoc
05-15-2009, 09:41 AM
oh my that sounds sick!!!!
Drgnblood
05-15-2009, 11:10 AM
i think i just creamed my pants.....
tybardy
05-15-2009, 07:30 PM
that is sexy
HMFDZ28
05-25-2009, 03:55 PM
Its not all that hard considering alot of the parts used you also can use lol. Play around on LS1sounds.com and there is a ton of cam vids and sound clips to play with lol
road1will
05-25-2009, 03:59 PM
sounds great. cammed GTOs always do. it sounds a lot like my 64 fairlane.
Max
05-25-2009, 05:32 PM
longtubes+tr220 would sound nasty as hell.
HMFDZ28
05-25-2009, 05:43 PM
found the cam it had... yeah and MTI X1 lol. 230/227 .591/.571 112lsa... not a big cam but a paired with big heads and 1 7/8th primary headers will do it
BlueTahoe2001
05-25-2009, 06:37 PM
Hell, If my Tahoe could sound like that I would spend all my life savings for that. But there are no cams, heads, ECT...made for our trucks
nc6600
05-25-2009, 06:40 PM
Hell, If my Tahoe could sound like that I would spend all my life savings for that. But there are no cams, heads, ECT...made for our trucksI beg to differ.
Max
05-25-2009, 08:03 PM
wtf are you talking about? the gen III lsx engines are one of the most supported engine platforms in the aftermarket, you can do whatever the fuck you want with these trucks.
HMFDZ28
05-25-2009, 09:07 PM
I'll give ya one example of how far off you are on that..... When the LS1's wanted a cheap way to raise the compression of thier motors they slap on a set of 5.3L heads :Handshake:
road1will
05-25-2009, 09:26 PM
spending life savings on modifying a truck? thats a scary though. of course at 16...i guess your life savings is still in a piggy bank
BOSS
05-25-2009, 10:04 PM
:Wedgie:
Shaggy
05-26-2009, 03:52 AM
That would sound wierd on a tahoe. :think:
Don't get me wrong, that sounds bad ass, but not sure how it would look/sound on a hoe..
BOSS
05-26-2009, 07:58 AM
I dunno.....after my interior is done, that's my next goal right there with a SC!
BOSS
BlueTahoe2001
05-26-2009, 12:58 PM
I haven't found shit for my truck...A 5.3L Vortec engine V-8. I only thing that I have found is a New Throttle body and a Supercharger and headers. Someone point me in a direction where I can find heads, cams, ECT...?
HMFDZ28
05-26-2009, 06:52 PM
Thats the issue.... stop lookin at the truck motor specificly. If you are lookin for heads or a cam you can use any Gen 3 LSX parts... IE LS1 (5.7), LQ4 (6.0), LQ9 (6.0) and the wee 5.3. The Dart 205 heads and cam I have sitting next to me will fit that motor even though it says they are for an LS1.
Volant1
05-26-2009, 07:23 PM
http://www.vincihighperformance.com/camshaft%20spec%20list%20page%20ls%20truck.html
Here you go
BOSS
05-26-2009, 07:29 PM
Here you go
Hell ya....thanks man!!!
BOSS
BlueTahoe2001
05-26-2009, 10:04 PM
So basically LS1 Parts will fit? If thats the case I have a friends who's dad is over the GM High Performance section I Might be able to get some stuff...
HMFDZ28
05-26-2009, 10:17 PM
Pretty much... I'm a big fan of Roger Vinci... the valvetrain goin in my Z28 is from him. The XXX cam sits next to me for now lol
Kingsize
06-11-2009, 09:48 PM
Thanks for all the great comments guys! :happy160: It's funny when you run into your own stuff on the interwebz.
Completely wrong cam. My cam size is... Hyd. roller XER Lobes .605in-.609exh 238-240 112deg lobe seperation
By the way, you guys have it all... tons of room and access to all the LSX platforms and the ability to swap any of them in, and a powerfull computer to run it all. Just got through helping out with a LS7 swap into a slammed Tahoe. Just a tune away from bliss now.
BOSS
06-11-2009, 10:50 PM
Hey man, welcome to the forum...I'm guessing you found us by searching on some of your engine mods???
Help us out, tell us about this LS7 swap you did or build us a cam setup like yours!!!
Thanks bro
BOSS
Kingsize
06-12-2009, 01:59 PM
The guy bought a used LS7 and pulled his motor out of his Tahoe (he spun a bearing), used his oil pan and converted everything to a wet sump system from the LS7's dry sump setup. We used all of his original electronics, coils, sensors etc., and he bought an aftermarket 90mm TB. The reluctor wheel on the crank is 58X instead of 24X so we used a Lingenfelter Performance reluctor wheel/trigger wheel electronic adapter module. It allows Gen IV GM V8 engines with the 58x crankshaft trigger or reluctor wheel and the 4x camshaft timing gear to be installed in earlier vehicles designed to accept the 24x crankshaft trigger wheel and the 1x camshaft trigger wheel. So far so good, just need to tune via EFI live for the injector size and then get on a dyno and tune.
As far as a cam, you can make just about any one fit, just make sure you check valve to piston clearance and/or notch your pistons with a piston notching tool from Isky or any other. Patriot makes great heads for the 4.8/5.3: https://www.patriot-performance.com/xcart/product.php?productid=38&cat=36&page=1 but, if you want the absolute best for your money TEA has it all. Check out the flow numbers http://www.totalengineairflow.com/products/gmhead/gmls1/
BOSS
06-12-2009, 10:03 PM
All in all, that's hurting my head....I wish I knew what you were talking about! Thanks for the great information and the leads!
BOSS
