Uneven ride height, truck is all stock
wade
I noticed for the longest time, my pass. side of my 03 denali is 1" higher than driver side. Suspension is all fine, compressor works, its all stock and in great condition. tire pressure is even all around.
why is the back pass side 1" higher and front pass. side is .75" higher?
Modded
That Guy
Because the gas tank is on the drivers side so its sags the truck on that side.
Its a known issue from the 00-2010 truck/Suvs....
W
wade
well thats crap. Can I adjust my pass side load sensor for the air ride so that it compensates for the difference thus adjusting it so it makes it lower on the pass side ( filling it with less air ).
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I evened mine out a bit by LIFTING the lower front corner. That also transfers weight back to the opposite (high) rear corner and evens the truck out both side to side as well as fore and aft.
W
wade
i am new a these vehicles, how do I lift the front on the lower side/
Eagle
EL PASO, TX
tighten the torsion bar on that side, probably 1 turn is all it will need. then go drive it around and remeasure the ride height on all 4 corners when you return
18mm socket.
http://www.tahoeyukonforum.com/forum/showthread.php?t=183
two changes:
1: no need to lift or jack up the truck
2: instead of marking a bolt you can not see, mark the socket or socket wrench.
I painted part of my torque wrench silver and marked the other half with black tape, as well as 1/2 the torque wrench body.
I can count 1/2 or full turns confidently.
01yukon
Lynchburg, Va
It's called the GM lean. My 04 Escalade did the same. I heard you can also adjust the air ride linkage, but I did'nt ever mess with it.
WITCH1975
