what do you think of this?
D
DJTricky
Banned
Robbinsdale MN
i just got off the phone with TransGo, it takes what ever shifter you have and converts it to manual, so for us. 1 would be 1st, 2 would be 2nd, 3 would be 3rd, and OD would be 4th. and it holds the gear (no up or down shift)
so its an automatic manual. so no need for the clutch.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
while it sounds cool. It would be really annoying to up and down shift all the time.
Rollin Thunder
Va Beach Va
ohhh...so if I was to leave it in (D)...it would be like starting from a green light in 4th gear...it would bog out?
From what it sounds like yes.
---------- Post added at 05:40 PM ---------- Previous post was at 05:40 PM ----------
also 2 on the gear shifter starts you out in 2. I do this all the time when its wet out in the silverado to keep the rear wheels from breaking free.
95TwinTT
Minnesota
The shift linkage was not made for that constant activity.
Here is a link to the electric version which requires wiring, but you don't have to crack open the tranny.
http://www.tciauto.com/Products/Electronics/default.asp
I see these on ebay from time to time, going for $250 -450.
You can add your paddle shifter to it and be able to switch back and forth from auto to manual. :)
Nickleahy23
Portage/Menomonie, WI
just get a normal HD2 shift kit..its 90 bucks
does the same exact thing..it holds all gears..i can hold 1st pask 6k and let off and it doesnt shift, if i start in 2nd, like normal is doesnt start in first, it starts in 2nd for easy launches in the snow etc..2nd will also hold past 6k and not shift into 3rd..3rd also holds as long as i want it too...
no need for this full manual..that would be a pain in the ass and you would get no gains over a normal shift kit..when would you want to just be in 4th?
dizhai
