Aftermarket projector/hid headlights
Tahoe03mm
Puyallup, WA
I have an 03 Tahoe that I did an Hid conversion like a year ago and wanted to put in some black or smoke projectors with halo accent. So I bought some on ebay that were supposed to fit tahoe 01-06 and 99-02 silverado. I went to install them and noticed a large gap (at least an inch or so) between the bottom of the headlight housing and grill which looked like *****. Also I checked fit with hood and with a deflector it's hitting on the top of housing when you close the hood. So I'm going to RMa them. So I need to find something else. Is the mount on the silverado slightly different? Halo accent is not a must but projector is. Please find me a good alternative ;)
MikeTheApeman
The armpit of America - New Joisey
The issue I've found with a lot of the eBay projectors is that they are plastic. I was going to use those when I converted my Jeep, but decided against in fear the plastic would melt.
If I can find a pair cheap enough on eBay, I'd buy them and retrofit glass projectors. The difference between the eBay projectors and quality projectors (pun intended) is night and day.
Tahoe03mm
Tahoe03mm
Puyallup, WA
Who makes a decent set of projectors? I was thinking of looking into the ones that the denali uses, but I was under the impression that would require changing mounts, wiring harness, and the grill and I don't really want to undertake that unless it's going to be semi-resonable
CincinnatiZ
Cincinnati and Miami
I had to take these apart and fix the adjusters to get them semi close. You can still see that I have the gap that you are talking about where the top light meets the grill. When my truck gets out of the shop (body mods) I will get them set perfect. Gotta love the HID's.
BOSS
The People's A D M I N
Dallas
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
Yes you can. I did when I had them on my mustang (same projector just different housing)
MikeTheApeman
I had to do a double take on this one, but you put the HID's in reflector housings? I know that folks are doing it for fogs here, but the fogs really don't have a bad beam pattern and aren't near eye level.
Are the rest of you guys running HID low's in reflector housings?
Sepiroth
I am here
Kouts, In
Hell, I'll sell you mine.
These are TYC projector headlights. They take an H1 bulb. Installed in them now are H1 silverstars.
I'll take $115 plus shipping.
Xav8r
Greater Sacramento
Hey NYTahoe/John-
Which projectors are you and RT referring to in your post above? I'm considering a few different ones right now, but really like the looks of the ones you posted above.
Thanks ....
WITCH1975
