PDA
View Full Version : Door lock problems
DwDrummer
11-06-2009, 02:54 PM
My drivers side door lock switch will lock and unlock all the doors except for the drivers door. When I unlock the doors using the key fob it will unlock and lock all the doors except the drivers. I have to manually open the door by hand and unlock the drivers side door by key. Has anybody ever ran into this problem or know what I can do to fix it??
Thanks,
DwDrummer
BlizzardX23
11-06-2009, 02:56 PM
sounds like the motor(or whatever does it via button) is going bad on you....the same thing is going on with my stepdads F150...but its the passenger side
only thing is...your truck is new.... :shrug:
---------- Post added at 11:56 AM ---------- Previous post was at 11:56 AM ----------
Does it feel like its just sticky maybe?
Modded
11-06-2009, 03:49 PM
I have heard this issue has something to do with opening the door with the keyfob when it was locked with a remote.
You can try locking all the doors and pulling the +ve battery wire for 15 minutes and then reconnecting.
I know it sounds weird but its worth the try.....
DwDrummer
11-06-2009, 04:38 PM
I'll give it a try man nothing can hurt! I'll report back!:Handshake:
---------- Post added at 03:38 PM ---------- Previous post was at 02:58 PM ----------
Well I just hooked the battery back up and it didn't fix it.....just my luck!!!!!!!!
Modded
11-06-2009, 04:40 PM
Then your door lock actuatuor is screwed....
scottrick
11-06-2009, 05:18 PM
same thing happened to me. and sometimes happens to the rear passenger door too....its been like that for like 3 months.....i am taking it in on monday finally
Mgyver1
11-06-2009, 06:14 PM
Probably the door lock actuator. Join the club....I've had 3 replaced so far, waiting for the forth one to go.
BlizzardX23
11-06-2009, 08:10 PM
why tho? his truck is new? so they arent from being worn out.....
DwDrummer
11-06-2009, 08:58 PM
Prolly a dumb question but what is a door actuator?
Mgyver1
11-06-2009, 10:27 PM
Nope they are from being cheap. When you install poor quality components they tend to break quickly. If you search it's a very common problem in the '07-up Tahoes.
BlizzardX23
11-06-2009, 10:48 PM
Damn...that sucks...wonder why the did that for the NNBS... :shrug:
Mgyver1
11-06-2009, 11:02 PM
Make more money. Gone long ago are the days of making quality stuff and earning an honest living. I would say most people could live rediculously comfortable on a $150,000 salary. But the big wigs of these companies need multi millions, hence brand new $35,000 to $65,000 trucks have junky door lock actuators. It would cost a few bucks more to have a quality product installed but then their profit margin would go down.
BlizzardX23
11-06-2009, 11:06 PM
Its just odd that this wasnt an issue with the NBS...but they downgraded for the NNBS...seems like they'd spend more money making the change then just sticking with their old product.. :disgust:
TEXAS DEMON
11-06-2009, 11:27 PM
that is the little motor,actuator that moves the rod atached to the lock. it what makes it go up and down up and down up and down........
and yeah if they are cheap they will burn out quick. you can either get a oem one which is better just to keep the stock plug or get a aftemarket one.
auto-loc is a very well known company for stuff like that. any audio shop can install one.
lowAZhoe
11-08-2009, 03:33 AM
there are issues with the 07+ door lock acutators. we usually replace all 4 at the same time. company that made them didnt do a good job, and im pretty sure gm went to someone else to make them. im surprised there isnt a bulletin on them, but if you go into the dealer and tell them the drivers door doesnt work at all and the others work intermittently im pretty sure they will do all 4.
Mgyver1
11-08-2009, 02:55 PM
Well my dealership did not do that, Findlay Chevrolet. Driver's side went out so I went up there and they replaced it. Month or so later rear diver's side goes out and they replace it. As I get back in the truck and double check it's all working I look and the rear passenger side isn't working. They want me to bring it back another day. After much protest and explaining that I live very far from the dealership and I can't be bringing my truck down there every other day because they didn't check and make sure all the rest of the junk actuators were working, they replaced the rear passenger side. Still waiting on the front passenger actuator to go out. Oh, and they didn't re-install the rear driver door panel correctly too.
Modded
11-08-2009, 03:15 PM
Time to find another dealership McGyver....
DwDrummer
11-09-2009, 01:26 AM
My tahoe is a 08 model with 36,2xx miles, do you think the dealer will cover it under warranty??
lowAZhoe
11-09-2009, 01:30 AM
its possible that they will good will it, but u might need to spend some money with them for them to do that. like some maintenance.
DwDrummer
11-23-2009, 11:56 AM
I got the lock fixed under warranty and it ended up being the actuator. Thanks for all help everybody!:D
syndicatesteve
11-26-2009, 06:23 PM
I had the same problem, took it to the dealer, they said it was a fairly common problem. it took them 2 hours to change it out. thank heavens for extended warranty
gbleezy
11-26-2009, 11:37 PM
x2
