View Full Version : Good time to do a head gasket change?
Saw this on ebay and was wanting to know
- what is the advantage of this gasket set over a dealer?
- should I wait to do headers before installing a new set?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360122819886&sspagename=STRK%3AMEWAX%3AIT&viewitem=
It has the following included:
Graphite head gasket
Intake manifold gasket
Exhaust manifold gasket
Valve cover gasket
Viton valve stem seals
Camshaft front
O-rings.
Other Small Gaskets
Thanks,
BOSS
PavementPounder
05-13-2009, 12:10 PM
I would go with dealer kit rather than that. Wasn't even sure who made it.
Sepiroth
05-13-2009, 12:14 PM
I would not go with a dealer kit. I also would not go with this or any other Ebay kit.
What I would go with is a Fel-Pro head gasket set. I've used them in the past and have had 0 comebacks, pertaining to the Fel-Pro products.
Felpro all the way, and get some L92 heads along with a nasty cam while you have it apart :imo:
mdtahoe
05-13-2009, 10:36 PM
There is no reason to replace the head gasket unless they are blown. They usually only blow if the engine has been SEVERLY over heated and there is coolant in the oil or exhaust gas in the radiator. They very rarely ever blown on GM trucks. It is a major job. If a vehicle has high mileage or coolant mixing with oil (enough to do damage to bearings) it is not recommended to go the head gasket because chances are the engine will not last long after. In that case it is recommended to replace the engine instead.
danimalmax
05-13-2009, 10:48 PM
how about a motherthumpr cam?
mdtahoe
05-13-2009, 10:50 PM
You do not have to remove the heads to replace a cam
JKmotorsports
05-14-2009, 04:52 AM
Use Fel-pro. Don't cheap out on gaskets or you chance having to tear down the components again to install another gasket(s).
tybardy
05-14-2009, 01:27 PM
i always like where your heads at... one of these days when my wallet catches us, im driving to denver and we are tearin into my motor!!
hey MDTahoe... this was always the impresion i was under as well, i had an old Toyota supra that i did a head gasket in (blew it) and had to re-do it 4 times (block, not the heads, was warped). Long story short, i always figured a head gasket would stay on untill it decided itself not to be there lol, but i am also a student not a teacher of auto mechanics so sometime i refrain from adding my .02
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
