View Full Version : DD nav in non-dd truck
JKmotorsports
05-13-2009, 10:02 AM
Here are some pics of the install of a double din Pioneer Avic-D3 in my 01 a while back. I took some pics of the brackets I fabb'ed and the the bezel I trimmed.
There are a couple different ways you can do this. One way is to trim the bezel, plastic weld ABS and re-finish the entire bezel. Another way is the way I did it below. I only wanted to spend one day on the entire install from start to finish so I did it the easier and faster way.
I took the clip brackets from a AI 95-02 GM truck dash kit. They need to be spaced apart 1/2" on both sides of the unit in order to clip back into the dash properly, so I used 1/2" scrap of MDF. I used my digital calipers to take measurements of where to drill the mounting holes and where to place the brackets so it would go into the dash right the first time.
http://i227.photobucket.com/albums/dd269/jkmotorsports/DSC06145.jpg
The MDF spacers/mount:
http://i227.photobucket.com/albums/dd269/jkmotorsports/DSC06146.jpg
The clips mounted to the spacers:
http://i227.photobucket.com/albums/dd269/jkmotorsports/DSC06147.jpg
I removed the entire radio/hvac housing from the dash to make fitting and trimming easier.
http://i227.photobucket.com/albums/dd269/jkmotorsports/DSC06148.jpg
http://i227.photobucket.com/albums/dd269/jkmotorsports/DSC06149.jpg
Behind the radio, there is a metal bracket that is held in place by two rivets and two screws. The rivets can be drilled out, then the screws can be backed out to remove the bracket to make room for the new unit. Some units will require this bracket to be removed, some won't.
The trim bezel needs to be trimmed in pre-03 models to fit a dd unit. I used my Dremel, asst of files, and finally different grits of paper to trim and round-over the edges of the new opening to match the oem edges. Some people mention using a 03+ bezel, but the problem is that you'll need to reposition the HVAC controls, and the contour along the bottom edge of the bezel won't match up perfectly if you have the full legnth center console that butts up to the dash.
http://i227.photobucket.com/albums/dd269/jkmotorsports/DSC06151.jpg
http://i227.photobucket.com/albums/dd269/jkmotorsports/DSC06153.jpg
PavementPounder
05-13-2009, 11:43 AM
Thanks JK. Stickie sticky stick
02tahoe
05-15-2009, 03:59 PM
Do you have any pics of that lower monitor center console monitor set-up? I have been thinking of doing that exact same thing for my back-up monitor. I have the remote cassette deck and the cubby hole with a door there. Was thinking there would be some way of using the tape deck connection as an ipod hookup.
JKmotorsports
05-16-2009, 05:52 PM
http://i227.photobucket.com/albums/dd269/jkmotorsports/Centerconsolescreen1.jpg
http://i227.photobucket.com/albums/dd269/jkmotorsports/Centerconsolescreen2.jpg
http://i227.photobucket.com/albums/dd269/jkmotorsports/Pioneerback-upcam2.jpg
http://i227.photobucket.com/albums/dd269/jkmotorsports/Centerconsolescreen8.jpg
nytahoe
05-16-2009, 06:30 PM
nice work and wright up
Timmy
05-16-2009, 07:18 PM
looks really good JK.
wanna buy me a DD?
nytahoe
05-16-2009, 07:23 PM
i did the tv like that in my 03.
http://i34.photobucket.com/albums/d141/tahoe2003/DSCF0405.jpg
http://i34.photobucket.com/albums/d141/tahoe2003/DSCF0398.jpg
Timmy
05-16-2009, 07:26 PM
glad you made it NY.
JKmotorsports
05-16-2009, 10:05 PM
Here's one I did in an 04 Tahoe:
Center console, 8" Pioneer monitor and DVD player:
http://i227.photobucket.com/albums/dd269/jkmotorsports/misc/Picture373.jpg
http://i227.photobucket.com/albums/dd269/jkmotorsports/misc/Picture379.jpg
Timmy
05-16-2009, 10:07 PM
good quality, but i don't like the cupholders. i guess i'm weird.
dec322
05-16-2009, 10:30 PM
JK, what do you do for a living?
I'm loving the nav! This is something I can show to my wife and she will be all over it! I just changed the radio out in my 95 silverado so those adapters are looking very familiar right now. Good work.
nytahoe
05-16-2009, 10:43 PM
yea cause i would use that for a movie & back up cam and the top one for nav plus it was down low. plus i had the 2 headrest done.
JKmotorsports
05-17-2009, 03:37 AM
Thanks man. I've been installing and working on automotive electronics and custom fabrication for about 17 yrs.
Timmy
05-17-2009, 10:14 AM
how did you get into it?
JKmotorsports
05-18-2009, 06:01 AM
I've always been into cars, electronics, and making things on my own whenever I could, so I took an electronics and automotive class in school. I worked on all my friends cars in school and a local shop took me in and that's where I started. I learned most of my fab skills from watching more experienced installers and also doing a lot on my own. I did more studying and acquired my MECP 1st Class and ASE A6 automotive electrical certs, and also did some studying in acoustical properties.
Timmy
05-18-2009, 09:17 AM
wow. that's cool. i've wanted to get into the same line, but i can't decide between that or culinary school
02tahoe
05-18-2009, 05:59 PM
Thanks JK. That was exactly what I was looking for.
On a side note you guys need to get the donations set-up. I have no usefull knoweledge to give but sure do get a lot of money saving info off of here!:Handshake:
Big Tap
05-19-2009, 06:03 PM
Yes, I agree...let's sticky this. This seems to be a common question dating back to the old tf.com site. Nice work on the '04 install JK. That looks really clean.
HMFDZ28
05-25-2009, 02:20 PM
What did you use to fill in the sides of the DD?? Is that just more MDF or did you use an ABS plastic? Looks awsome BTW. I had to deal with this in my camaro and well its on the list for the truck.
Big Tap
05-25-2009, 03:34 PM
He mentioned on the old forum that it is ABS plastic. It's a pretty good looking install.
HMFDZ28
05-25-2009, 03:46 PM
Cooo thanks for the info!
titanium02
10-15-2009, 12:48 PM
Tag.
JK I'm comin to TX in the spring.. I'll drop the yukon off and you can take care of the HVAC LED's and the Double Din :)
coopiesb
10-24-2009, 06:33 PM
http://i628.photobucket.com/albums/uu5/cooperthetrooper/newpics220.jpg
elicpse double din just used the install kit
fatnlowtahoe504
11-18-2009, 08:45 PM
you didnt do all the cutting with that one or something? what year is yours?
JKmotorsports
11-19-2009, 01:02 AM
Coopies is at least an 03 or newer model that has the corporate dd hu. You can tell by the hvac controls in his pic.
coopiesb
11-19-2009, 02:16 AM
yeah its an 04....... just had the plate that goes around it to fill the din...
JKmotorsports
11-19-2009, 01:26 PM
So for those who don't know, the 03+ models already utilize a dd unit, so all you need is the avg $20 dash kit. But unfortunately, to integrate with the databus controlled hu, you're also going to need the more expensive wire harness/module.
Sam Hamm
11-20-2009, 06:43 PM
the picture where you built the bottom screen for the 04 with a dvd player. did you use mdf or what to build the trim around the tv? and old same with the cupholders/dvd player.
and also what did you cover or paint it with.
fatnlowtahoe504
11-23-2009, 01:21 AM
yea i didnt know if coopies was a 03+ LS or a 00-02 LS AC controls, i wish i could have a DD so bad, i would have to cut up my painted dash bezel to accommodate it...
JKmotorsports
11-23-2009, 04:07 AM
I used MDF and fiberglass.
Kyle C.
12-04-2009, 04:43 PM
So did you utalize dash kits from pre 03 and 03+ to get the flush finnish? I'm thinking of tackling the same job myself, I usually wouldnt even think of cutting or trimming the dash but you made it look pretty easy. I just want to make sure I can get the nice finnish look.
JKmotorsports
12-04-2009, 05:40 PM
I used the brackets from the older pre-03 kit and cut the rest of the trim pieces myself.
jmildoc
02-02-2010, 07:40 PM
what kit did you buy that will clip into the factory cage that we already have?
z71tahoe
03-05-2010, 09:35 PM
very nice install
bigrhino
05-13-2010, 10:06 PM
I have a 2002 tahoe, would a 2003-06 benzel fit and be an easier install?
BOTTOMLINETRACKS
06-18-2010, 04:30 PM
i would like someone to put a dd din in my white 2001 tahoe with full console. I live in ny..long island.
BigDawg99
12-29-2010, 08:33 PM
i went to my local walmart Today and all they had was Scosche products...You wouldnt know the part numbers that i need for my 02 Yukon Denali..I dont really Care about the Chime and the Onstar...just want to get a DD installed on my Truck...
gdddup
02-07-2011, 12:22 AM
just finished my double din install in my 2000. this how to was so helpful. props to JKmotorsports
04ctd
02-22-2011, 09:29 PM
http://avic411.com/index.php?/topic/26611-d3-in-an-01-tahoe/page__gopid__227716#entry227716
JK, why are you using a D3?
I have one, and have learned it's quirks, but it's not really great at anything, but it is "good" at a few things
since they are aging, and becoming cheaper used, i was gonna get another just to prevent having to learn the quirks of another Navi system.
do you think I can use your method to put a DD in here:
it's a 2000 tahoe OBS
http://i19.photobucket.com/albums/b170/04vrscb/DSC02541.jpg
mtyler7807
04-28-2011, 07:27 AM
I did this about a year ago. PM me if you need more info.
StephenC
07-24-2011, 02:45 PM
Just did mine in my 00 Hoe it was wicked easy going off of what you showed here.
Thanks man
jasqid
10-27-2011, 09:31 PM
Hey JK, quick question for you on the 2002 truck DD install you did. (here: http://www.tahoeyukonforum.com/forum/showthread.php?t=595)
When you cut your dash bezel, did you also trim the piece between the radio and the cliamte controls, or was it soley the top and top right of the radio's bezel?
I've got a 2002 Tahoe and got all the tools to do what you did (with the exception of the digital calipers). I'm still debating with myself to cust the radio cage out like you did too.
jasqid
11-05-2011, 08:35 PM
THANK JK,
I was able to put a 2 DIN in my 2002 Tahoe from your example.
dwmmatt23
11-18-2011, 01:02 AM
my pioneer p3300bt double din is on the way so im tackeling this project next week, more confident after reading this.
01yukon25
11-19-2011, 02:10 PM
New here, been looking at the forums since i got my 2001 yukon. Where do i get the clips at and how much do they cost?
ekordas
01-16-2012, 03:33 PM
Very nice setup.
TWITCH101
01-20-2012, 09:53 PM
When replacing the stock stereo do you keep the functionality of your rear controls? I'm talking about the center console for the second row of passengers.
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
