rear drop ?'s
MOBmentality
Has a $25,000 Punch
a coil over on a yukon? ........................
Im lost immediately.... you mean just a coil spring? If so, Yes. Get relocators... and i would at LEAST remove the bump stops if not do the djm free travel mod.
Or itll ride like cold stiff doookie
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
yea the factory shocks will bottom out, you need shock relocators or some drop shocks (not expensive), the free travel mod is when you cut off the whole little metal structure (layman terms) or brackets that holds the factory bump stops so that you get more travel in your suspension and not always bottoming out... http://www.gmfullsize.com/forum/showthread.php?t=171419 Max just did a thread on there how he did his...
NORCAL SS
SUV SUSPENSION GURU
id get new shocks hit me up i just need to know your eye/eye ride height and get you dialed in.
djm suspension has a link on their tech section ont he free travel mod
01burban
springfield,missouri
o tried calling you because i had a few ?'s
but does any one know where i can get the relocaters and also if just lowerd my torsion keys all the way it sat about a inch off my tires up front bc i have 305/40/22 and i put in the djm 5 inch drop kit would it sit almost even ? because i measured it and the back would be like a 1/8 lower
jackal78
