2" to 3'' lift or blocks and torsin keys
magnahoe
MA
I want to give my 4dr 4wd little bit of a lift. I want to go higher then a few inches but I live in MA and we have ride hight restrictions. Do you think the Rough Country 2 to 3 inch kit is worth it or should I go with blocks and keys. Right now I am running stock hight with 31s but the frame seems really low to the ground.
bowtiefreak
No Quarter
Near Philly
a 2-3" lift is my vote, less stress on the front end. Happyspaz just put a similar lift on his truck, I would look up that thread. A body lift is an option but as you stated the frame is too low to the ground...a body lift will not bring that up other than a little from larger tires. And as I always do I recomend a 6" lift...if you can afford it and pss the lift inspection. Many 6" kits are more like 4-5" then a t-bar crank for the other inch or two. I always say go larger because you will want it bigger in no time. I have a true 6.5" lift in the front with a little crank to about 7-7.5" ....still too low for me
M
magnahoe
MA
Yeah, I think I will go with the 2 to 3 inch lift because you cant beat the price and it is my first truck and I don't want to go crazy with it. I just want enough clearance for some mild dune trails, and the beach. Thanks for the advice.
any one have any pics of their hoe with the lift?
hapyspaz
Austin
Here's what the 2-3" lift with torsion bars cranked looks like:
2 1/2" box kit for the front from SkyJacker
4" lift SkyJacker Soft Ride springs in the rear
(with 2" drop shackles - don't ask)
Torsion bars cranked to level it out
Fenders sit just shy of 40" at center of wheel
275/70/18 Goodyear Wrangler DuraTrac
jcooklock
Tampa, FL.
I actually like the look of that one. just a little higher from what I have now. I dont want to go bigger bc I dont have the money to buy larger tires, and I just got the ones I have now
TIM Z
DMAX Power
Navarre Ohio
Thats a great lookin ride hapyspaz!
I dont reccomend Green keys at all.
Terrible ride, idler/pitman arm/ ball joints wear quicker, Terrible ride
Its a cheap lift but thats it. its not worth it.
Jumpshot12
