View Full Version : trailer hitch
dans99
10-14-2009, 07:57 AM
I was at the junkyard and seen a frame mounted receiver from a 97 suburban. Would it fit a my 99 tahoe??
bai78
10-14-2009, 09:10 AM
It should, check the mounting locations & compare with yours.
dans99
10-20-2009, 12:33 PM
Thanks. should it be bolted up or would welding it be better?
bowtiefreak
10-20-2009, 03:21 PM
I would quess and say most people bolt them up. What are you looking to tow?
dans99
10-24-2009, 08:53 AM
I wont be towing anything big I just have a 12ft. boat for duck hunting but I like having the option of towing something bigger if need be.
99YukonJS
10-25-2009, 06:39 PM
After a quick search, yes it will fit.
Mine is bolted on. It's a class 3 rated at 5,000lbs. You could reuse the old fasteners or buy new ones, but just go with high grade bolts. :)
dans99
10-25-2009, 09:17 PM
Thanks guys, I am going to get some good grade bolts and bolt it up. not a bad find at the yard for $20
1weasel
10-26-2009, 01:29 AM
If I can tow a 21' open bow without welding one on, you can tow a 12' hunting boat.
dans99
10-28-2009, 08:21 PM
Ok....next question;) what size bolts do I need to use to mount it up?...Thanks again guys.
99YukonJS
11-13-2009, 10:21 PM
Sorry for the late reply... :)
Did you figure out which bolts to use ? If not, when you removed it, did you keep one of the old fasteners ? You know...just to use as reference. :D
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
