window speed
Tribalbreak
WARminster PA
hey guys, just a question, anyone elese have super slow windows in the front? its more my driverside front. the rears are normal speed the passanger is alittle slow, but the driverside goes so slow that it sometimes stops. seems like its just loosing power. any body herd of this or had this issue?
danimalmax
louisiana
the only thing i think i read about that may help with that kind of thing in general is a big 3 wiring upgrade, but im not sure
but about your window sometimes stopping, thats a whole nother issue, i think
T
Tribalbreak
WARminster PA
yea its slow slow slow then eventually just stops... then i hit the switch again and it finishes going up... but very slow
jomulk56
Resident Lurker
IN
Maybe the motor is going out on the driver side?
T
Tribalbreak
WARminster PA
i thought electric motors were either on or off or intermittent... i dident know they slowed down or stopped but started when you re- applied the button... regulator?
JKmotorsports
Austin, TX
Probably time for a new motor. Driver side usually quits first since it is the one used more than the others. Electric motors can wear overtime. The brushes wear out and can build up dust or even a glazed film that can add electrical resistance, slowing down the motor.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
my passenger window in the silverado is nice and fast. But I just put a new motor in. Driver is super slow. even though it works im thinking of replacing it cause im sick of it being so slow. I can hold both switches up and the passenger will be up before the driver is even half way up.
T
Tribalbreak
WARminster PA
thanks guys, ill take it in the the stealership and get it replaced under my warenty... only 50 bucks for the deductable... ill have them replace the driver passanger and the pass. rear because that one does not work at all...
T
Tribalbreak
WARminster PA
with the warranty i have its 50 or 70 per visit to the dealership i got the truck at as long as the work is covered
Max
Mile High
Denver
I've pulled apart window motors, cleaned and regreased them with great results. Not sure if the case is serviceable on these trucks tho, used off ebay would be cheap tho.
rdtahoe
NJ
Happened to me on my '00 5.3L. Replaced motor and regulator (dealer part), about $150 I think. Motor toasted out.
Volant1
Volant guy
Upland, CA
When I traded for my tahoe they didnt work at all, I rebuilt my rears and they are plenty fast, I bought new motors for the front and they were slow I thought it had to do with the cable system in the front
WITCH1975
