My 2004 Escalade
NathanJax
Vacation Nathan
Jax, Fl
Now that most of my truck is basically done, I figured I'd post some official pictures...
2004 Cadillac Escalade 6.0L AWD - Fully Loaded From The Factory
Exterior Mods:
OEM Esclade 22" Rims with 285/45/22
Colormatched Grill
De-Badged
Replaced Puddle Lights & Reverse Lights With "Cool White" LEDs
Tinted Tail Lights & 3rd Brake Light
Interior Mods:
20% Tint On The 2 Front Doors
35% Tint Down The Entire Front Windshield
4% Tint Over The Factory 20% Around The Rear
2005-2006 Factory Touchscreen Navigation
Aftermarket Footwell Lights
Audiovox Back Up Camera #ACA200W
Factory Ipod Interface PAC #uPAC-GMC2
Factory Video Interface PAC #VCI-GM2
"Platinum Edition" A/C Vents
"Platinum Edition" Guage Cluster
Replaced ALL Inside Lights With "Cool White" LEDs
Rear DVD Player Wired To Front Navigation Screen
Performance Mods:
Cold Air Intake
Corvette 2nd Gear Transmission Servo
Magnaflow exhaust 12599
Royal Purple Max-Gear Fluid In Front Differential
Royal Purple Max-Gear Fluid In Rear Differential
Royal Purple Synchromax Fluid In Transfer Case
Suspension Mods:
3/4 Ton Chevy Stock Torsion Keys in Front 1" to 3" Lower
AIR LIFT 1000 Series Rear Air Spring Helper Bag Kit #60769
Bilstein HD Rear Shocks #F4-BE5-6500-H0
Bilstein HD Rear Shocks #F4-BE5-6501-H0
Belltech 5" Rear Coil Springs #5305
Belltech Rear Shock Extenders #6651
DJM 3/4" Urethane Rear Bump Stops #10S
DJM Free Travel Mod
Eibach Front & Rear Sway Bars #3882.320
McGaughy's 2" Drop Spindles #33004
Max
Mile High
Denver
Those tails turned out perfect! Where are your adjuster bolts at for the tbars? Pegged? I kinda like the stance looks like the front is a bit higher than mine :cheers:
Effeckt
Resident Cards Fan
Phoenix, AZ
I like everything but the emblems on the exterior. It really looks great though aside from that. You've done a great job with it.
JKmotorsports
Austin, TX
Truck looks real good, bro. Made a huge difference when you swapped the rims and dropped it.
Donnie Yukonie
Yates Caretaker
So you have had a hoe,yuk and esk all modded and Fly..... you sir are baller with a taste of class :Handshake:
I these are all other people's rides that he just stalks :shrug: he really drives a 93 Nissan Sentra
WITCH1975
