09 Yukon Stereo / Dash Removal
zKing
Took a few pictures while taking out the stereo to put in an uPac-GM29 device to add real iPod functionality to my existing factory stereo. I've been looking all over the internet for days and unable to find anything anywhere.
I knew that it had to be easy but I really didn't want to damage my 2 week old SUV .. lolol
Enjoy :)
syndicatesteve
Syndicate Steve
Southern California
Kicker car audio is making many new pieces to add ipod intigration to factory head units. check with your local KIck dealer to see if they sell them
bocaytomas
zKing, did they really make you remove the entire radio?!?! When I put in my Ipod Integration from Coastal Tech, I just dropped down the glove compartment, install two two minutes, cause I zip tied the cables...
snowjay
Same with my USASpec. I mounted the control box on top of the heater core with double stick tape and zip tied the wires to the dash support frame then ran the cable so it poke out from under the HVAC controls.
tast101
Colton, CA
nice, now just turn it into a little write up and throw it in the tech section. You guys need some more write ups in this 07+ section.
Z
zKing
I had to take off the stereo bezel and take out the stereo to plug in the cables for the uPac directly into the back of the stereo. Getting at the back of the stereo through the glove box is impossible on my 2009 Yukon. I did however fish the wires that go to the actual uPac controller device and mount that in a small space beside the glove box .. also ran the cable for the iPod into the glove box itself.
snowjay
Do you have XM?
I have a 2009 Tahoe so same interior as you. My USASpec intercepted the wires at the XM controller which is behind the glove box. No need to get at the back of the stereo. But I think if I didn't have XM then radio removal would be necessary along with an additional adapter cable.
08denali
What a pain
Hey I just removed my bezel. Just an FYI, it is very tedious and takes much patience to remove it without scratching everything. One hint, they simply pop out, but you have to give the first one a pretty good pop to get things rolling.
blaqout
King Yukon
Indianapolis
Thanks, man! I plan on installing a Pioneer AVIC u310BT in my Yukon and that helps a bunch. The only problem I see is that I may have to cut that wall behind the radio. Has anyone installed on these type of stereos in their 07+ Yukon/Tahoe?
TEXAS DEMON
with a vengeance
texas
it will depend on where the rca's and rest of the wiring are on the back. but most likely you will do some triming. break out the dremel!
mikeb33
Inverness, IL
Anybody else done this?
I can see from the picture it just snaps in, but I am having a hard time.
There is practically no room to insert a screwdriver or pick. I tried a metal pocket ruler, but it just flexes. I also tried a pocket screwdriver, but as I pry, it just presses into the vinyl dash. I am afraid I will leave a mark.
Any other tips or tricks? I am trying to install a Gen 5 Lockpick.
nytahoe
"Tha Butcha"
new york
pick up a set of plastic pry tools.
yes you have to cut out the plastic behide the radio. its all so dubald up. if i rember right.its a tight fit but i will go.
blaqout
King Yukon
Indianapolis
Man I just installed a Peripheral Electronics iPod adapter and I agree it was a pain to remove that bezel, I sure wish I had a set of those tools mentioned above! I will definitely be investing in them for my "real" stereo install, LOL!
WITCH1975
