someone please school me on gas mileage and o2's please
redemn93
Jupiter, Fl
so my tahoe has 125k miles on it. i just replaced the plugs with the delco replacement iridiums last night. wires also cause most broke while removing them. i am pretty sure they are the factory plugs. delco calls for a .040 gap and these were worn to .060 (some a little more, some a little less).
i am concerned because i have only gone 150 miles on half a tank. i have been driving it a little hard but nothing that should have eaten gas like that. i also dropped in a K&N and new fuel filter. next week i am going to remove and clean the TB and change the PCV valve. im reading that you guys say a tune helps a good bit with MPG?
now to the point. with 125k miles, should i change the o2's even though i have no CEL? is there a set (front or rear) that affect MPG the most? or just dont mess with it until i get a light?
once i get all the maintanance and small problems fixed i would like to do headers, exhaust, and the airbox mod with a smooth tube to the throttle body. maybe a ported TB and a tune. all in due time. thanks for any help!!
COTahoeLS
Senior Member
Colorado Springs, CO
The front o2 effects your gas mileage. The rear one is only used to check cat efficiency (read, doesn't do a damn thing really).
I would recommend possibly replacing the front o2 with new one and then get a tune as you will gain at most 1-2 mpg through the tune alone (read, 25-50 more miles per tank).
-E
R
redemn93
Jupiter, Fl
these are dual cat trucks right? so there are 2 front o2s. i may do that this weekend. thanks.
JamesinAbilene
