PDA
View Full Version : least expensive way to drop my hoe
road1will
05-11-2009, 04:15 PM
Alright, i think ive decided to drop my tahoe and put some 20s or 22s on it.
I think i'll probably just do a 2/3 drop but would entertain doing a 3/5 drop, but im sure a 3/5 will be more than what i want to spend.
So who can give me some pointers on the most economical way to drop my hoe?
Volant1
05-11-2009, 05:43 PM
Torson keys and springs it will be under 200, or you can just get the rear springs and turn down the torsons this is what a 2/3 looks like on 20's
road1will
05-11-2009, 05:53 PM
that looks good, and same color as mine! i'd love to do some NNBS LTZ 20s
jomulk56
05-11-2009, 06:07 PM
Well the cheapest way would be to crank the torsions and cut the rear springs. I never said it was the safest. I would actually buy a kit with spindles though.
Max
05-11-2009, 09:45 PM
Stack your loot and do it right, 2/4 drop with spindles and springs along with some air helper bags would ride great. You can go the cheap route with keys and some ebay springs but you'll change it all later, trust me. Oh and anyone that cuts the springs on these trucks stay the hell away from me on the highway, shit is sooo sketchy cutting a progressive rate coil in a truck this heavy.
NJ04HOE
05-11-2009, 10:04 PM
Somebody I work with did his that way with the keys and rear springs and it looks great for less than $300. He even says it rides better, if I drop mine I think that would be the route I take. I'm not sure if it makes a difference cuz I didn't look into yet but his is a 2wd mine is 4wd.
Drgnblood
05-11-2009, 10:15 PM
can you pm me a setup that you would recommend?? everything down to the last bolt......i was thinking 2/3...on my 2wd hoe...
Max
05-11-2009, 11:06 PM
What shocks are you running? The big ass gas shocks? Autoride? Front is easy, belltech 2508 spindles. Rear I would do some belltech or mcgaughey's 3" drop coils, shock extensions, and bilstein HD shocks for factory application at all four corners. Then buy some larger sway bars; hellwig, belltech, hotchkis, suspension techniques all come to mind. Also replace all your front end components with napa premium or moog products before they wear out and slowly cause the truck to ride like shit. My truck runs 10x better, rides REALLY well for the amount of drop, and handles 100x better than my friend's uber low mileage 06 Denali that I drove recently. I think that a truck running the aforementioned setup would be very fun to drive everyday, esp with a tvs blower under the hood.
Rollin Thunder
05-11-2009, 11:12 PM
drive it up to the top of the parking garage. Put a brick on the skinny pedal. Jump out. A dropped hoe.
road1will
05-11-2009, 11:36 PM
I wouldnt ever cut a spring on any car and then take it on the road. Perhaps ill just wait a bit longer and save up to do it the right way.
Max
05-12-2009, 12:11 AM
excellent decision. I'm contemplating stock keys and buying control arms, love my 5" front drop tho.
Nickleahy23
05-12-2009, 12:37 AM
Whatever drop im at right now im loving it..its technically a 3/5, but the front is up a little bit cuz my front end is worn out, and the rear has the "big gay shocks" that max and I discovered..once i switch out the shocks in back i will hopefully be down a little more..I wouldnt mess with the 2/3 cuz you will want to go lower..heres my "3/5" ish on 24s..the front is perfect for me and once the rear comes down a little more ill be happy
http://i121.photobucket.com/albums/o204/nickleahy23/CIMG8034.jpg
http://i121.photobucket.com/albums/o204/nickleahy23/CIMG8041.jpg
road1will
05-12-2009, 02:04 AM
Can you post up a parts list of which front end NAPA components your refering to?
Thats something i'd like to to do my hoe to make her ride new again. I have a few friends with tahoes/suburbans with 100k+ miles that im sure would love to do this project.
also, how many miles on your denali?
blueflamed03
05-12-2009, 10:41 AM
Nick, your Hoe is so clean man....love it.
PavementPounder
05-12-2009, 10:46 AM
Nick, what shocks are you going to use? Is your Hoe 4wd?
Volant1
05-12-2009, 11:55 AM
My tahoe is a 4wd also
Grocery Getter
05-12-2009, 07:15 PM
I ckeckef Ebay everyday and was lucky enough to score a McGaughy's 3/5 kit with keys/spindles-front:springs/control arm relocator/sway bar linkage-rear
For $360. A deal like that goes quick so you have to look every day. I have seen 3/5's used on Craigslist here in Phx for less than $300
road1will
05-12-2009, 08:49 PM
wow thats an awesome deal..if you come across a similar deal again post it up here!
Max
05-12-2009, 11:24 PM
I have almost 100k on my truck running extremely well. Here is a list of the napa part #s you'll need
Inner Tie Rod Ends - NCP 2693124
Outer Tie Rod Ends - NCP 2693122
Idler Arm Pivot Assembly - NCP 2683717
Idler Arm Assembly - NCP 2683714
Pitman Arm Assembly - NCP 2681673
Gusset the idler pivot assembly to the frame like so:
http://cognitomotorsports.com/store/media/images/idler-pivot
Also look at replacing the intermediate steering shaft with a borgeson billet piece, part #000937
https://www.borgeson.com/catalog2/product_info.php?products_id=782&osCsid=84e702d91dff9b0f4409bca55937c3f1
http://www.borgeson.com/TRUCKS/chevyshaft.jpg
Rollin Thunder
05-12-2009, 11:27 PM
to drop your hoe. Take her to a bar, Get her real drunk. Shoot her in a dark ally, and drop her in the river. The cops will think it was a suicide and your scott free.
Max
05-12-2009, 11:57 PM
You're still not funny dude. It's chill tho my pops humors himself all the time we just ignore him :cheers:
Rollin Thunder
05-12-2009, 11:59 PM
I aint trying to be. I just dont like lowered shit. :adminpower:
road1will
05-13-2009, 12:01 AM
What exactly are the signs that the ISS needs to be replaced? I know they are a big problem area for our trucks...but i've never heaerd what the symptoms of a worn ISS are...
Max
05-13-2009, 12:02 AM
Well that's your fault for being a douchebag then.
Steering wheel clunks, random uncentering of the steering wheel, excessive wheel adjustment at highway speeds. There is a bunch of info floating around, makes the trucks steer alot better tho.
road1will
even sports cars? sedans?
---------- Post added at 12:02 AM ---------- Previous post was at 12:02 AM ----------
sting!
Grocery Getter
05-13-2009, 12:08 AM
So why waste your time reading a thread about lowering? I wouldn't come and chime in a thread about making ur neck more red......
:Plugged:
Rollin Thunder
05-13-2009, 12:56 AM
sting!
REally no. Changes the look in a bad way.
---------- Post added at 12:56 AM ---------- Previous post was at 12:56 AM ----------
:Plugged:
I wouldnt care if you did.
Modded
05-13-2009, 03:51 AM
LoL RT is a lowered hater....typical Republico conservative Nazi who believes "his way or no way">>>>lol RT I'm joking!
By the way RY why dont you lift the kon.....just don't want to?
thumper_ehhhhh
05-13-2009, 04:46 AM
man you guys missed it. the cheapest way to lower your hoe is to let the air out of the tires. It might drive like shit but it is the cheapest.
Fyrcaptain
05-13-2009, 06:21 PM
Max,
What is the reason for gusseting that idler pivot to the frame like , and what is that blue part?
road1will
05-13-2009, 06:36 PM
Max,
keep it from flexing when turning? tighten up steering? im just guessing here..
Modded
05-13-2009, 07:54 PM
LoL some certain people are attemtping to whore this thread!
Max
05-13-2009, 08:00 PM
Max,
crikey enough questions dude? do a bit of reading off cognito's website and you'll hopefully understand. they try selling you the entire pivot assembly and include the gusset, just welding a gusset for a napa replacement piece is more than enough imo
taken from cognito's website:
The Cognito Motorsports pitman idler arm support kit takes care of the issues with the centerlink side of the pitman and idler arms. There is however another weak link in the front IFS steering on the 6 and 8lug GM vehicles. The idler pivot assembly tends to wear out, bend, and even break under stress with as little as 35” tires. The idler pivot assembly is what the idler arm is mounted to, and pivots on. Cognito offers an aftermarket idler pivot assembly in order to strengthen your weak stock parts. The aftermarket Idler Pivot assembly has tapered roller bearings, adding strength and durability, thus creating a solid pivot point for your steering components. It doesn’t stop there. The idler pivot assembly mounting tabs tend to twist or even dislodge from the frame. Included with the kit is a weld in gusset in order to strengthen the weak factory mounting tabs. This kit is highly recommended, even more important than adding our heavy duty heim jointed tie rods. Play in the idler pivot can cause major tie rod issues. If the idler pivot assembly has an issue, the idler arm is able to move uncontrollably. As this happens you will have drastic tie rod angle changes. In certain instances a bent or failed part can cause complete disaster to your front end. Some damages may include: idler arm rubbing the transmission oil cooler lines or motor mount, pitman arm, idler arm, and tie rod breakage. Most tie rod problems stem from worn or damaged pitman and idler arms or idler pivot assembly.
DESIGN
05-16-2009, 09:28 PM
Max, corrected me if I'm wrong but don't you do this for a living? At least i thought I remembered that from TF.
Either way, I am very interested in doing a complete suspension uprgrade and rebuild. My nearly 100k 03 Tahoe is in need to some suspension work.
My plans over the next two months are to piece together a complete set up and put it on all at once.
Key components to my upgrade are a 3/5 drop, sway bars, and new shocks (I have the oversized rear ones but not autoride). I will also take your advice and upgrade the stock components and mine needs the steering shaft repleacement.
So from the experts, what is a good budget for these parts?
Long winded post but all (helpful) input is appreciated.
Thanks,
Jon
Max
05-16-2009, 10:23 PM
I'm trying to finish skoo but work at a shop to pay the bills. I'd say 3/4 ton keys, belltech or mcgaughys springs, airlift helper bags, bilsteins, shock extensions, and all the front end stuff. I'd figure about $1000 for parts, front end stuff is expensive check out www.rockauto.com
road1will
05-17-2009, 12:02 AM
Who? You?
tybardy
05-20-2009, 12:41 AM
i really want to drop my hoe... REAL bad... of course i catch a lot of shit for wanting to drop a Z71.
whats stopping me is the money its going to cost for me to drop the truck if the same cost to do things i REALLY want like LTs and Cams and all that...
anyways, Max still brings up a good point about the Inner + Outer Tie rod ends, Idler arm's and pitman arms... i am almost 100% sure i need to get all this shit replaced in my truck ASAP.
Rollin Thunder
05-20-2009, 12:51 AM
Preformance first, defiantly. I wanna do the same mods here. I wanna cam, headers, exhaust, etc. Then next year after the shock of the new room, New outdoor kitchen, new car, my bad tax bill, wears off. I will put a super charger on the silverado, and get some headers, cam, CAI, exhaust for the yukon.
tybardy
05-20-2009, 01:00 AM
how neccesary would you say those airlift helper bags are? or is that just a recomendation for those who already have the autoride?
Rollin Thunder
05-20-2009, 01:03 AM
IM not sure. My 06 had auto ride and my 07 does not, Cant say I notice much different other than the 07 might have a firmer ride.
My silverado has ride control and I can tell you the helper bags really help when I have a ton of weight in the bed (like 50 sheets of drywall, or lumber, and stuff)
Max
05-20-2009, 01:01 PM
Sway control and it prevents bottoming out. I still haven't done the free travel mod on my truck, just a half dozen other people's. The helper springs act as a bumpstop, mine lift the truck 1/2' with 7psi or so but it's worth the added height for the improved handling and ride improvement.
tybardy
05-20-2009, 01:49 PM
yea the height isnt my main concern as i will only be lowering my truck a few inches... but at the moment, as i mentioned, my suspension is shot and i am trying to get a feel for what i can/should do to improve the ride all the way around. $1000 puts me at waiting a little while so i can stack some bread though
Rollin Thunder
05-20-2009, 01:50 PM
put some blistine 5100s on there. People at the z71 site do that all the time. I have done that to the silverado and LOVE IT, Ride is so much better and truck has a much more solid planted feel on the road.
Fyrcaptain
05-20-2009, 08:15 PM
crikey enough questions dude? do a bit of reading off cognito's website and you'll hopefully understand. . [/B]
Well excuse the fuck out of me for asking.....thought that's what these forums were for, and I don't know who the fuck cognito is in the first place to initiate the research.......dude!
Now go back to studying.....dude....lol.......
road1will
05-20-2009, 09:25 PM
well excuse the fuck out of me for asking.....thought that's what these forums were for, and i don't know who the fuck cognito is in the first place to initiate the research.......dude!
lol
Max
05-20-2009, 11:26 PM
it's ok sweetheart, you're forgiven.
