PDA
View Full Version : Black Bear Tune nearly done...
Yuke2K
04-30-2009, 08:27 PM
...but with some issues. My MAF sensor is reading low, and neither me nor Justin can figure out why. It's not the sensor itself, I just replaced it due to this issue and the truck is STILL not pulling enough air for some reason. I have gone over the intake tube with a fine-tooth comb, and there are no cracks, no dents, no damage...hell, not even very many scratches. I cleaned all of the mating surfaces, the worm clamps, the rubber connectors, everything...and got a ton of crud off of them. I thought for a second that maybe the glue holding the rear of the accordian-shaped rubber connector on the tube might have a leak, so I cleaned it up and put a bead of RVT silicone around it to make sure it was sealed. Still, no dice. The reading is more stable since I've replaced the MAF, but it's still reading lower than it should.
Justin is compensating for the problem with the tune, but I HATE having an unsolved issue that has to be corrected with software, rather than fixing the issue itself. It's not the intake manfold gasket, I specifically asked. I honestly don't know what else could be wrong. I guess I will just have to use this as an excuse to get an aftermarket intake system. :D
Funny thing is, my truck usually gets DISMAL gas mileage. Like, 13.5 mpg average. After the first couple of datalogging runs I did ( I've done a total of five becuase of this frappin problem with the MAF), I was down to 12.5 average. Then, I cleaned up the intake and did all of that stuff, and even after two more datalogging runs in the mountains, my truck has jumped to 15.6mpg average as of my fill up today! Obviously I fixed SOME sort of intake leak, but the MAF is still off? What gives?
Shaggy
04-30-2009, 08:32 PM
I like Justin!! :rocking:
Yuke2K
04-30-2009, 08:35 PM
Heh, I have a feeling that I'll like him a whole lot more once the new PCM is in the mail. It's going out tomorrow, so next week is party time. :party33:
Shaggy
04-30-2009, 09:09 PM
Thats always a good reason on liking someone, when they get you something for free :Handshake:
05Yukon
04-30-2009, 11:06 PM
I don't think its free. I believe he did the scan cable tune.
Yuke2K
04-30-2009, 11:36 PM
Correct. I've got about $600 ($350 of which is refundable equipment deposits) plus two tanks of gas wrapped up in this tune so far, but I sincerely hope that the end result is worth it. From everything I've gathered on Tahoeforum, it will be. I'm very, very excited...even with my MAF sensor being retarded.
Shaggy
04-30-2009, 11:59 PM
I now the tune wasn't free, I thought he was sending you something that was free, read it wrong :Boo:
05Yukon
05-01-2009, 01:18 AM
Its ok we have all read something wrong before.
puckhead
05-01-2009, 02:30 PM
Hopefully you will get the problem fixed. Keep us updated though. The black bear tune is great though! You will enjoy it!
Yuke2K
05-01-2009, 08:54 PM
Yeah, I think that fixing the actual problem isn't going to happen at this point...Justin and I are both at a total loss as to what could be causing the MAF sensor to read the way it has been. So, he'll tune around it and all should be well in Yukeland, lol. He said that the new PCM will probably go out today, so hopefully I'll have it installed by the end of next week. I need to burn through the current tank of 85 and refill with 91 beforehand though.
Timmy
05-01-2009, 09:09 PM
i can't wait to get mine. :[
Yuke2K
05-01-2009, 09:53 PM
Yeah, the wait time for the cable was only about 6 weeks in my case, but I think that since the weather is getting nicer, the list might start getting long again. Even though they just bought a ton of new cables, they go fast.
JKmotorsports
05-01-2009, 10:00 PM
You're gonna love it man. It's like a whole different truck bro.
shsportsfan12
05-02-2009, 03:52 PM
13.5 mpgs?? Damn... that's what I'm getting on average with a heavy foot with my truck on 37's.... Maybe I should clean my intake and see if I can boost it up some like you did.... damn you for inspiring me to do something productive with my day
Yuke2K
05-02-2009, 04:01 PM
Yeah, something was NOT right with that. I only recently started tracking my mileage with the Fuelly app on my blackberry. I've been taking it super easy with this tank to see what my highest mileage will be BEFORE I install the tuned PCM. Then I'll at least have a baseline to see how much I've gained from the tune.
shsportsfan12
05-02-2009, 04:02 PM
Don't take it really easy. Drive like you normally would.... I say this because having it tuned is incredibly fun and will be hard to keep your foot off of it.
Yuke2K
05-02-2009, 04:26 PM
Well when I get the new PCM installed, of course I'll be pushing it a little...I'll want to see what my truck can do compared to stock! I'm just driving like a grandpa right now to see how much mileage I can squeeze out of the stock PCM before installing the tuned one. Then I'll (painfully) do the same thing for one whole tank with the tuned PCM, and see what how my max numbers compare to each other.
munks06denali
05-03-2009, 01:16 AM
TB gasket mat be causing your MAF sensor leak, or you just got a bad MAF
Grocery Getter
05-03-2009, 08:18 AM
Ah-ha! This is what's holding up my cable! I've been on the list for like 6 weeks and #2 for two weeks. I can't wait for my tune!!!!!!!!!
Gmoney_2010
05-03-2009, 01:15 PM
so with the cable tune, justin has to send out a separate PCM? I thought it was all done over the computer with the cable?
Toadster
05-03-2009, 01:41 PM
have you checked all your maf wiring? could be some type of corrosion or bad connectivity - enough to run, but enough to screw it up
JennaBear
05-03-2009, 02:52 PM
No, but that will be possible once the AutoCal comes out! :Handshake:
Gmoney_2010
05-03-2009, 03:00 PM
what will be possible?
JennaBear
05-03-2009, 04:29 PM
To email the tune logs to customers and allow them to download tune to their PCM on the spot.
The current cables only log the driving information for Justin to base a tune off of. He still has to flash a computer with the tune and ship it out.
SSmurdered
05-03-2009, 04:49 PM
just got my tune done yesterday. we had a meet here in pittsburgh pa. i highly recommend getting a black bear tune even better have him do it in person. i got the 93 tune and love it so far. my shifts are lovely and WOT has lots more pull once the 26s get spinnin. when i put my 16s on for the winter im drifting this bitch! jk.
tybardy
05-06-2009, 12:16 AM
yea man, i had some spiders in my intake system that i couldnt seem to work out either... i did one data log, Justin brought a "leak" to my attention, i uninstalled everything, cleaned it out and re-installed everything thight as a drumb... still a fucking leak... so justin tuned around it... however i know EXACTLY how you feel about the unresolved issue, it never leaves my mind! i always think about how much better it could be if it wasnt fubar....
Hey Jenna, when is this AutoCal going to be ready? that sounds freakin sweet!!!
JennaBear
05-06-2009, 12:24 AM
We have a Beta version to test for EFILive, so we are hoping that they will start producing them for the masses soon!
tybardy
05-06-2009, 01:22 AM
let me know if you need any test run guinea pig... im your man :D
