Need your experience
Mr.Hoe
Dammam,SA
Hi
I just got Chevy tahoe 95 and need to lift it from the front 3'' lookin for cheap liftkit price with good Quality, help me pls on that ???
bowtiefreak
No Quarter
Near Philly
Are you asking how to only lift the front 3"? Find a 4" suspension lift (Rancho), that will give you about that in the front. What are you doing out back?
M
Mr.Hoe
Dammam,SA
I have blocks around 3" ready with me for the Back Can I find only the front liftkit or should be all kits ??
by the way I like your tahoe in the Signature almost I want to lift tahoe like your tahoe what you install on it ???
99COOP
Retired
Chicago, IL
i still dont really understand what your asking, but if you have 3" blocks in the back then you can crank the keys 2-2.5 inches and sit fine. but i woldnt go higher then that. if your asking about buying a lift they make 2-3 inch kits which would be fine or 4" kits, but that would be a waste, minus well go 6" :imo:.
bowtiefreak
No Quarter
Near Philly
I have a cepek 6.5" lift on mine...a bit taller than 3". Everythign you find will most likely be a "kit". The rear part of that kits will be a block. So with that said the kits are mainly the frony differential drop anyway, that is where the cost is coming from.
M
Mr.Hoe
Dammam,SA
I will check (Rancho) liftkit I will lift my hoe 4" if you can help me with good website have good prices give me the links
Thanks
sc00bz
South Paw
If you want a cheaper suspension lift kit look into a RCX. You may want to wait and save up for the cepek tho because as soon as you lift with something smaller you WILL wish you had gone bigger and there's not a whole lot out there better than a cepek lift IMO.
M
Mr.Hoe
Dammam,SA
I want my Tahoe to be like the Tahoe in my Sign what do you think cool or not ??
bowtiefreak
No Quarter
Near Philly
I might be a little biased about that truck since I own the same one with a 6" lift. Yes it is very cool.
WITCH1975
