Z71 Bumper replacement
Chris
A few people have done it, you interested in doing it yourself or taking it to a shop?
Drgnblood
Drgnblood
F%ck Douchebagistan!
Douchebagistan for now
im not sure yet....i dont have equipment to do it but i could get access to it....how much work is it..?? Could i do it over a three day weekend?? oh and where do i get the paint...online....automotive body shop?? sorry all the questions??
Chris
Sand it down, use some adhesion promoter, high build primer, color, clear. All can be done with a rattle can if you would like, depends a lot on the color of your truck. It could easily be done over a 3 day weekend. What color is your truck man?
---------- Post added at 09:00 AM ---------- Previous post was at 08:58 AM ----------
http://www.gmfullsize.com/forum/showthread.php?t=27648 give that a look, its an awsome write up and the guy did a badass job. Should give you an idea if its something you want to try yourself
---------- Post added at 09:02 AM ---------- Previous post was at 09:00 AM ----------
Oh and rollpan looks like it doesnt fit quite right imo, check out jk's I think his is the best I have seen on a ** or kon
Drgnblood
Drgnblood
Sandalwood mettallic
I'mma check it out
yeah i kinda saw that but i wanted a second opinion
Hey thanks by the way
Chris
Well I painted my chrome grille shell and I sanded it down starting with 500 and smoothed it all out with some 1000. The I hit it with adhesion promoter (2 or 3 coats), then some self etching primer, some black duplicolor, about 3-5 coats (a lot to avoid chips) then hit it with the clear coat, I lost count after 8 coats here. Then I sanded with 1500 and finished with 2000, used some rubbing compound and a coat of wax. It hasnt chipped and has help up fine to all kind of weather. First time I did it I did not take the time and just sprayed black and clear and it was chipping in a matter of days. I did mine in a weeked (fri-sun). If you have any other questions man just let me know.
Drgnblood
Drgnblood
man that sounds like a job but i guess i gotta pop my cherry sometime.....
Drgnblood
Drgnblood
Do i need to buy a sander or can i do this by hand??
jomulk56
Resident Lurker
IN
I'd do it by hand. You can get into the tight spaces better, and follow the curves better.
WITCH1975
