spring iscolators???
goozdenali
Banned - Bad dealings with members
massachusetts
Hey gonna be installing my 3/5 kit on friday, just wondering what they were and if I remove them will I get a lower drop?
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
My Bell Tech kit instructions said to leave them in place... but I wanted slightly more drop in the rear, and removal of the isolators was the trick. I don't know that your isolators will differ much from mine, which are about 1/3 of an inch each when not compressed.... and probably yielded 1/2 inch of additional drop. Here's a pic of mine... they are the four round pieces sitting between the bump stops.
Grocery Getter
A guy with a truck.
Phoenix, Az
Yank'em, you'll get about 1/2-ish more drop. While you are down there you should do the free travel mod and cut your bump stop brackets off all together. You can do it in 10-20 min with a swazall and like 5-10 with a plasma cutter. It makes all the difference, the ride is as good as stock if not better......
WITCH1975
