Instructions for installing mcgaughy's #33048
tahoe
Hi! I'd really appreciate it if someone can help me (step by step) on how to install my MCGAUGHY'S #33048 2"/3" DROP KIT for my 2003 CHEVROLET TAHOE 2WD with 305/40/24. Thank you.
Modded
That Guy
It may rub, or may not. Belltech did a NNBS Avalanche with 4" of front drop with 305/45/22 tires and had 0 problems.
And in general, thats a taller and wide tire than you plan, but then again you could just go 295/35/24 tires and be safe?
T
tahoe
OOOPS! Typo, I mean 305/40/22. Will this be a problem also? Thanks
matt14
san leandro,ca
I get some rubbing on hard bumps and when i turn lock to lock. I'm alos running the same size tires as you. I'm also a little lower then you,so shouldnt be a problem.
T
tahoe
Thanks a lot.
---------- Post added at 11:46 AM ---------- Previous post was at 11:45 AM ----------
Hi, would there be any problems or pointers with the installation of the Mcgaughy's lowering kit #33048? Thanks
matt14
san leandro,ca
Rear is cake. I'm running drop front a-arms and wasnt all that bad. Spindles cant be any different then the a-arms. To be honest, its been over a year since i isntalled it, so cat really remember. I work on cars all day long, so hard to remember.
T
tahoe
Thank again. I really appreciate it.
brucebruce45
there's no way a 305/40/24 tire will fit with a 2/3 drop without rubbage...unless u do some major fabbin. hell it's almost 34'' tall.
048tahoe
