View Full Version : places to run wire through firewall?
jESse
08-26-2009, 08:03 AM
are there any stock opening that are easy to get to to run some wire though? right now all i have is a small 14ish gauge wire but i'm also considering adding a sub later. i was hoping to skip drilling a hole but i kinda doubt i'll be able to do that.
groundscr8pr
08-26-2009, 05:49 PM
under the dash is a relay center. if you remove the cover for the relay center and press the two white clips at the top together you can swing the relay center down toward the floor. behind it you will see a large rubber grommet you can run your wiring through.
tast101
08-26-2009, 06:35 PM
That's where I ran my cable.
jESse
08-27-2009, 07:50 AM
awesome. i'll look for it next time i get a chance to work on it. thanks
00yukon
09-08-2009, 04:40 PM
i ran mine through the floor just infront of the drivers seat. i have 6 runs of 1/0 gauge running through it so there is plenty of room
SSmurdered
09-09-2009, 01:42 AM
large grommet = "juicy grommet" on driver side firewall. easily visible from under hood. a grommet wire runner thing makes quick work of it....just stab the tool into the grommet then feed the wire thru the hole in the center of the tool then go into the truck and pull the slack. ive seen them up to 4 gauge, great investment for an installer.
vBulletin® v3.8.7, Copyright ©2000-2012, vBulletin Solutions, Inc.
