Governor removal
CHOO CHOO
BackPagePhil
Manheim, Pa
Jenna, can the governor be removed by the autocal? Just curious if that was possible so I won't have a light on my dash for pulling the chip.
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Someone told me to pull the ECU1 chip and that would remove the governor. But I figured pulling that would cause the check engine light to come on and I don't want to see that crap. How do I get that removed?
On another topic since your here, I just put my rims back on and put a 2/3 drop kit on, should i get another set of tunes for the larger rims and drop or will it matter? The rims are 24's. Thanks for your help btw!
JennaBear
Resident Ninja
San Diego, CA
Not sure who told you that, but I wouldn't recommend removing that fuse- would have more ramifications than just disabling the speed limiter.
If you are changing wheel size, then your speedo is off, so you probably want to get that tuned to be calibrated.
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Does that cost me anything? No big deal if it does just curious. And do I need to record some data for you and send it to you or how does this work.
JennaBear
Resident Ninja
San Diego, CA
No need for data, just shoot an email, and we will get the tune set up for the 24s. No cost either.
WITCH1975
