thumping from my wheel
preshus
washington,IN
ok so on my gurls camaro drove it last nite and it started thumping real hard
like a flat and sounded like a flat . . . get out check everything and its all
completly fine start goin again just as i get to bout 5mph it starts knocking
again but when i put my brakes on it almost completly goes away so i
figured it was brake caliper took tire off and i can wobble the disk in and
out. . . called parts store he says it may be tie rod or ball bearing . . . ? ? ?
and i mean no exageration i get past 5mph it really knocks the whole car
and sounds something like compression and knocking it has that psh psh
sound its hard to explain
preshus
preshus
washington,IN
well iv tried everything i can think of i took the brake calliper off and all i can get is a
clicking sound from the wheel bearing ben told thats normal but its pretty loud goin down
the road now . . . after i put the brake caliper back on i took it down the road from
0-40 and its not doing anything it did last night so i guess maybe a cylinder on the
caliper was sticken maybe and loose lugs on top of that. . . i did notice its missing
connecters for the a arm to the sway bar on passenger side but i don't think thats
the problem
JamesinAbilene
