Question about Bilstein shocks.
Eckl
So naturally my autoride system is leaking. I'm looking at two replacements...
1. Bilsteins. Is this a direct swap that still relies on the air compressor? Or a pre-charged air/gas shock? Honestly, I don't want something that still relies on the rest of the crap 9compressor and sensors) failing.
2. Strutmasters conversion kit. It's a progressive system that converts air to non air suspension.
Any comments?
05Yukon
Houston
The bilsteins are a direct replacement that is still an air shock and still uses the compressor and everything. I dont know anything about the strutmasters kit.
DenaliAK
Colder than you
Alaska
I'm looking at the Bilstein/Arnott air shocks. They still use the compressor, but it deletes the electronically adjustable portion of the shock. And, they are guaranteed for LIFE as a Bilstein product.
wade
so if the bilstein doesnt need the adjuster, how does it know when the truck is not level
DenaliAK
Colder than you
Alaska
They aren't auto-leveling, they just use the compressor to adjust to heavy loads. I don't know how it's triggered.
DenaliAK
Colder than you
Alaska
lol
No kidding. I'm weighing the options, too. Not sure which route to take.
wade
i tow a lot and like to have my ride as level as possible, so what is best
E
Eckl
The benefit I see from using a progressive shock replacement, is that you don't need to rely on the compressor or sensors anymore. So farther down the line, you don't need to buy a new compressor when it craps out also.
And how does the Bilstein auto level with the compressor if the sensor is disconnected?
DenaliAK
Colder than you
Alaska
I'm not an expert by any means, but this is how I think it works:
The OEM shocks are electric air shocks. The electric part softens or dampens the ride depending on the road conditions. This is the part that would be disconnected with the Bilsteins. The air part does the leveling based on load, which would still work. That's what I've come up with after talking to the guys at Arnott Industries (the ones that sell the Bilsteins), anyway. I still don't completely understand it, although it more or less makes sense in my head now....lol
E
Eckl
Ah yes, so the 'auto level' sensors are still working, just the dampening electronics are bypassed. Gotcha!:cheers: Right on! Thanks for the research!
So have you made your decision now??
I'm STILL on that damn fence lol.
DenaliAK
Colder than you
Alaska
As soon as I can get the money together, I'm going with the Bilsteins. It's still waaaay cheaper and from what I've heard they actually ride better then the electric shocks.
wade
looks like I am ordering the Bilsteins end of the week and a new compressor for my Denali from Arnott.
Max
Mile High
Denver
I LOVE my bilstein HDs, just order some 3.9ohm resistors and you won't have a service ride control light.
wade
Max, it says on Arnott they come with something to plug into your sensor on the truck that keeps the service engine light away... so why the resistors then?
DenaliAK
Colder than you
Alaska
I don't think those are the same shocks. They are both Bilstein, but I think Max has the standard shocks, the Bilstein Heavy Duties. The Bilstein/Arnott shocks are still air shocks that the two companies jointly produced.
Max, does that sound right?
Max
Mile High
Denver
Yus I have the standard application factory replacement shocks, the arnotts work w/autoride but I just deleted all that crap.
JamesinAbilene
